Results 1 to 4 of 4
    Established Member Two Rings socals4's Avatar
    Jan 15 2010
    91 BMW 325i (e30), 2001.5 Audi S4
    San Diego CA
    Code for EGT and now also o2
    I got a 17867 code for EGT sensor 2 implausable signal. Cleared it and now getting that code again and now also a 17521 bank 1 heated o2 sensor 1.
    Should I just try relpacing my drivers egt and hoping that o2 was being thrown because of it? These things are expensive. Also What are the difference in EGT to o2? is it location like front and back?
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Apr 07 2007
    Columbia, MD
    I had the exact same codes and they just got worse. The implausible signal will intermittently cause the car to go into a type of limp mode where it will not make full boost. I also noticed that when driving at fixed throttle position on a flat road (i.e. no load change) the engine would fall off rpm as if I had let off the gas. I just bought and installed 2 EGTs from PureMS on sale and all of my problems went away. If you have any of those symptoms, then you will need new EGTs especially with the codes. X-mas around the corner - treat yourself now. Fall driving is outstanding - 45 degrees crisp and cool dense air - find some Mustang Cobras to defang..
    2001.5 M-box Nogaro, Autospeed K04/RS6 hybrids, fueling, downpipes, manifolds, ER ICs, UUC VM3 exhaust, UUC SS, Vogtland GTs, Enkei 18x8 w/ Hankook Ventus RS2 235/40-18, ASP street engine and trans mounts, ASP stabilizer, APR bi-pipe, APR snub, ASP rear-diff mount, AWE boost gauge, Aquamist HFS-5 methanol injection, DBA front and rear slotted 4000 series rotors, Hawk pads, Braided lines, ASP custom tune, ASP RS4+ clutch
    Established Member Two Rings BITURBOB5's Avatar
    Apr 24 2008
    01.5 S4
    Harrison
    I got both egts for sale used with 70k on them if u wanna buy them pm me
