Results 1 to 10 of 10
    Senior Member Three Rings tamaneri's Avatar
    Apr 02 2007
    New Jersey (Northern)
    swapping the downpipe
    Hey guys,
    I have my car jacked up. I am trying to replace the down pipe. My current down pipe is raped.
    Anyway. I was wondering how you would get access to the bolts that connect the test pipe to the down pipe. One of them is semi easy to access, the other 2 look rather difficult to access due to a heat shield that protects the cv boot from the hot downpipe/test pipe.
    What tool would you normally use and how would you go about doing it? thanks guys.
    Taylor A. Maneri
    2003 A4 1.8TQ B6 Black/Black
    Unitronic Stage 2 | TT 386cc injectors | RAI test pipe | Magnaflow 16601 | Milltek downpipe | Forge 007 DV | rs4 rear sway | vent pod boost gauge | JHM short throw | 034 engine mounts | ARP snub | ECS RA4 stage 1 clutch/flywheel | Bilstein / H&R
    tamaneri (AIM)
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    There are DIY's here for both down pipe and test pipe replacement. The DIY's are for a B5 but the B6 is essentially the same. It may help a little to have the visuals: Clicky click
    Apr 02 2007
    Thanks for the DIY. It helps a little bit. I am stuck trying to get the top bolt off where the test pipe connects to the down pipe. I got the other 2 (3 total connect it together).
    There just doesn't seem to be a good angle to knock that bolt loose!
    Taylor A. Maneri
    tamaneri (AIM)
    Active Member One Ring sherwin@034's Avatar
    Apr 08 2010
    Late 2001 vw passat
    Bay Area, California
    Have you tried Disconnecting the cat from the turbo and loosening up the clamp connecting the "midpipe" from the rest of the downpipe? By doing that you can slide the whole assembly towards you giving you a little more room to play with.
    Sep 08 2010
    Asheville, NC
    i stripped 3 or 3 bolts to my cat when installing my test pipe and ended up having to cut the downpipe in half and re welding it after. save alot of time. BUT dont strip them is what im saying. the downpipe and cat/testpipe wont come out together.
    Apr 02 2007
    still working on this.. LOL.
    i have 2 bolts reconnected on the new downpipe where it connects to the test pipe. working on the other one.....
    Taylor A. Maneri
    tamaneri (AIM)
    Apr 02 2007
    Hey guys. I have everything back on. However, there seems to be a small leak where the downpipe connects to the rest of the exhaust system.
    I was unable to use the stock clamp (i guess the milltek downpipe is slightly longer than the stock one). If I used it, the rest of the exhaust wouldn't line up properly and I couldn't bolt it back in place.
    I have the midpipe connecting directly to the downpipe. However, The clamp won't get tight enough, hence the leak. I bought a universal pipe clamp from Pep Boys, it said was 2.5", but I tighten it all of the way and it's still loose as a goose.
    What the heck else can I use/do?
    Taylor A. Maneri
    tamaneri (AIM)
    Veteran Member Four Rings EBG 18T's Avatar
    Mar 27 2005
    The Cold North
    Quote Originally Posted by tamaneri View Post
    My solution was:
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
    Apr 08 2010
    Late 2001 vw passat
    2.25" clamp should do the trick
    Veteran Member Four Rings PRY4SNO's Avatar
    Jun 28 2007
    1990 Coupe quattro with all the parts
    Edmonton, AB
    To access the downpipe at the test pipe I found removing the heatshield to be easiest.
