Results 1 to 9 of 9
    Veteran Member Four Rings adr3naline fix's Avatar
    Dec 17 2008
    Sold 01 1.8T, 05 Mini Cooper S JCW, 04 ZX10R Track
    Milwaukee
    5-Speed Transmissions (B5) interchangeable regardless of Code?
    After hours of searching, I received conflicting feedback. I need someone that knows whether or not B5 5-Speed transmissions are interchangeable regardless of transmission codes. If the gear ratios are a bit different, that is fine, as long as it is a direct bolt-in.
    I ask because I have an ENP transmission (rare and expensive), and I want to put in a DWR (abundant and more inexpensive).
    thank you VERY much to anyone that can help me out!
    My car is SOLD
    2001.5 1.8TQM || GT2871R Hybrid Elim @ 24psi | Unitronics Custom | 307awhp | etc | $15k+ in parts alone
    Jul 11 2008
    Vail, Co
    Can you give more info on what the ENP came out of? Generally, yes, they are interchangable. I have swapped several B5 1.8t trans. with B5 2.8 trans, and they were a direct bolt-on.
    Dec 17 2008
    Milwaukee
    Quote Originally Posted by flandog View Post
    ENP is the 5-Speed that can come in the 2000 & 2001 1.8T AWD
    My car is SOLD
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    yup, all b5 manual trannys are interchangeable as far as bolting in. the ratios are different but they will all bolt up to the engine,axles and driveshaft. 2.8 and 01 axles are different on the hub side but are the same on the trans side.
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Jul 11 2008
    Vail, Co
    if it's out of a 2000 or 2001 it certainly will bolt up. BTW my 2000 1.8t had a DWR, and I put in an O1E 6-speed, but that is a whole differnt animal.
    Dec 17 2008
    Milwaukee
    For clarification - the rear diff will be 100% o.k. with the "different" transmission? (DWR's different ratio than ENP)
    My car is SOLD
    Dec 17 2008
    Milwaukee
    Just found this
    So the ratios in all 1.8T B5 transmissions are the same? I take it my differential will have no idea what 5-speed I put in there, as long as it's a 1.8T, regardless of code.
    My car is SOLD
    Nov 09 2006
    Bronx, NY
    Your diff wont see any difference, even if you put a 2.8 trans in there. they all have a 3.89 final drive
    2000 A4 1.8tq
    Dec 17 2008
    Milwaukee
    For future reference, I swapped them out today. 100% interchangeable.
    Original Code: ENP
    New Code: DWR
    My car is SOLD
