Results 1 to 20 of 20
    Established Member Two Rings Trevor Ely's Avatar
    Apr 14 2009
    '88 E28 535is, '00 B5 1.8TQMS
    Hickory, NC
    Another clutch/fw thread...
    Hey folks,
    I hate to bore OGs with another one of these threads, but I was hoping that maybe there were some updates since I last looked at this topic a while ago.
    Anyway, I was wondering what would be the recommended route for a clutch and flywheel for my current setup...
    B5 1.8T (ATW)
    -GIAC J31
    -K04-15
    -Apikol SMIC
    -5Bar FPR
    -Labree HFC
    -APR/Borla cat-back
    ...Last I looked, I recall a handful of folks loving on the Clutchmaster FX400, 6-Puck clutch and either a Clutchmaster 240mm Alum. flywheel or a 228mm Steel flywheel. Basically, what I'd like to know is any experiences you guys have had with either of these products, and any other suggestions really. Currently, the car utilizes some sort of SMFW and stock-like clutch that the previous owner had installed.
    Any help is appreciated!
    Trevor Ely
    '00 A4 1.8TQMS - '85 2.3-16 (Euro) - '95 540i M-Sport (1 of 200) - '09 M3/4 - '91 M5 - '12 Fiat 500
    Gone: '88 535is - '87 325e - '89 325is - '91 318is - '90 325is - '96 328is
    Jun 23 2010
    Athens, PA
    FX400 sounds like a good setup to go with. go with the steel LWFW also. Minimal to no gear rattle and perfect clutch/FW for DD IMO.
    Apr 14 2009
    Hickory, NC
    Nice to hear that...Where does one purchase a setup like this?
    Trevor Ely
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    www.ringer-racing.com has pretty good prices, I got mine from there. The FX300 might suit your needs as well; but the FX400 would be great if you consider getting a bigger turbo in the future.
    I have the FX400 with a 15lb Steel LWFW and an 8 puck/full face disc. Its real nice!
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Senior Member Three Rings JK35's Avatar
    Apr 08 2008
    97 B5 TQM
    SW Florida
    Segmented Ceramic/steelFW is a good choice for you. it will work well now, is remarkably streetable, and will take you well into big-power land if you choose to go that route.
    I think that more importantly than your list of modifications, would be your intended use and how you drive the car.
    I used a SEGMENTED (that's what you're describing when you say 8 puck full face disc) Southbend ceramic and an AWE aluminum FW first time around with 442-496AWHP. It lasted 1700 miles (about 40-50 full power launches and about 8 hours on the rollers) before it began slipping horribly. Andy at SB built the plate as far as he could go with a Sachs Race PP (for free) milled a new friction surface for the AWE flywheel (the friction surface I bought from AWE appeared to be mild steel, not to mention they sell bolts that are too short for their flywheels. - I think I proved this quite completely, but they still sell the same bolts that only catch 2.5mm thread) and only charged me for a new disc at cost. I now have a graphite ceramic 6 puck and a chromoly flywheel and I have about 50 launches and 3000 miles on it and have sprayed about 40lbs of nitrous (direct port, progressive 4 stage) and during inspection teardown last week it was in remarkably good condition.
    I advocate Southbend. As much as I'd LOVE to have a CM twin disc, I can't overlook the awesome customer service and the way they stand behind their products at SB.
    Also, I have had aluminum flywheels in every car I have owned in the past 10 years, and I now know what folks mean when they say these cars don't like aluminum flywheels...
    steel and chromo FW's are almost as light and work much better on this platform IMO, and I surely haven't lost any power on the rollers, nor anything that I can feel. In fact, I think I've gained a couple (hundred) HP if my memory serves me correctly ;)
    when I mentioned your goals and how you drive... my initial Segmented stage V SB I killed... that was a 650ft/lbs rated clutch, and I cooked it with over 150ft lbs less. SB's fault? -hell no. MY fault, It's because I built the car so I could drive it like I stole it. -and do just that
    -be honest with yourself when you're considering ratings and specs.
    Apr 14 2009
    Hickory, NC
    Thanks for the information...To answer the question regarding driving style, the car's driven daily and will probably never see the drag strip. It's driven 'spiritedly' once in a while.
    I basically was just interested in a little better feel, and it's nice to know that it could be abused if necessary. Kind of like having a fancy watch that works several hundred feet under water. ;)
    Trevor Ely
    Veteran Member Four Rings terraflata's Avatar
    Sep 14 2008
    '97 Audi 1.8TQM '97 Acura Integra 2002 Dodge Durango
    Chambly, Quebec, Canada
    Quote Originally Posted by JK35 View Post
    I absolutely love your outlook on your car!
    MontrealAudiClub
    Apr 14 2009
    Hickory, NC
    So, time is nearing when I'll need to finally replace the clutch and just wanted to get a few more suggestions on this topic, as I'm considering going the route of CM FX400 matched with their Steel flywheel...I'm unsure which of the two puck selections makes the most sense, though... (4 or 6?)
    I know these are all items I could discuss over the phone with CM, but I'd like to be somewhat educated on this and have some more suggestions before placing an order.
    Thanks again for the help!!
    Trevor Ely
    Oct 17 2009
    is attached to my house.
    alonE, Pa
    Holy old thread. Go 6 if you had to choice from the two.
    '02 1.8TQ - Daily sold
    '05 Colorado Z71 Crew Cab
    STEVE
    Oct 09 2011
    Farmingdale, NY
    I have a clutch for sale in the classifieds, PMed.
    Apr 14 2009
    Hickory, NC
    Thanks for the messages everybody...One question that I've wondered is how much the lightened flywheel helps the revs? Is there a pretty noticeable difference in quickness of revving? One of my big complaints with this car, which might also be contributed by the DBW, is the annoyingly slow way it revs.
    Trevor Ely
    Registered User Four Rings
    Feb 08 2011
    B5 A4 2 liter HTA3586r
    Phoenix, Arizona area
    Quote Originally Posted by Trevor Ely View Post
    The problem is not the DBW, it is the fact that the flywheel is dual mass and about 25 lbs. You will even see a difference in throttle response going with a single mass flywheel that is the same weight as the stock dual mass flywheel. Giving you a better throttle response. The lighter the flywheel the easier the rpm's will rise/fall. For a daily driven Quattro you want to stick with the steel flywheels that are in the 15-20 lbs.
    Apr 14 2009
    Hickory, NC
    Understandable, that was pretty much what I figured.
    My only concern was that the current flywheel in the car was described by the P.O. to be a single-mass unit, chosen because it was considerably less expensive. The P.O. was an older gentleman who kept things original, so I'm guessing it was something OEM or possibly the Valeo SMFW alternative that I've noticed is now offered.
    Anyway, looking forward to some improvement, as it does rev painfully slow.
    Trevor Ely
    Apr 14 2009
    Hickory, NC
    Old thread, I know...But, had another question for some of you guys.
    When I was looking on Ringer Racing there was an option for the friction surface....Ceramic or "Feramic"? Benefits or downsides to either?
    Trevor Ely
    Feb 08 2011
    Feramic is a mix of Sintered Iron and carbon. It has a high coefficient of friction then Ceramic and a higher melting point. So it will hold a bit more power then Ceramic. The Feramic material is also more expensive and harder to get.
    Apr 14 2009
    Hickory, NC
    Thanks for the clarification...I'm guessing the Feramic would be entirely overkill for my uses and lack of power.
    Trevor Ely
    Feb 08 2011
    Yes. Ceramic would be way more then plenty for a J31 setup.
    Apr 14 2009
    Hickory, NC
    Quote Originally Posted by M-Hood View Post
    Great! Thanks for the help, went ahead and ordered the 240mm Ceramic FX-400 6-puck with the lightweight flywheel...Will follow-up with experiences!
    Trevor Ely
    Veteran Member Three Rings Urtorsen's Avatar
    Feb 09 2009
    chicago
    Where'd you buy it???
    Oct 17 2009
    alonE, Pa
    Wow, what are your plans?! Thats a 625ft-lb rated clutch!
    STEVE
