Results 1 to 4 of 4
    Active Member Two Rings legodudepatrick's Avatar
    Feb 17 2010
    Boulder, CO
    Add HD Radio to B8?
    Hello all,
    With the addition of HD Radio in the 2011 models, would a radio swap add this to other B8's? is there a separate add-on module, change some vag-codes? What do you guys think? I think I would rather do a radio swap then re-signup for Sirius.
    Veteran Member Three Rings dirtysoil's Avatar
    May 23 2009
    23 Tiguan; 22 RS5; 18 SQ5
    Indpls, IN
    I would love to know if this is possible also. Hopefully this would be a rather inexpensive swap, but I doubt it.
    Senior Member Three Rings a4_bob's Avatar
    Mar 13 2010
    Atlanta/GA
    Considering the HD radio is only available as part of the 2011 Nav package, I'm guessing that you would need to already have nav (MOST bus) and that you'd have to replace the entire head unit. Probably pretty pricey. Pure speculation tho.
    2011 BMW E92 M3 Competition
    Previous: 2011 B8 A4 Loaded | Meteor Gray, APR Stage 2
    Previous: 2009 B8 A4 Stripper | DeepSeaBlue, APR Stage1
    May 23 2009
    Indpls, IN
    Anyone.....
