Results 1 to 4 of 4
    Veteran Member Three Rings A4B7Quattro's Avatar
    Jun 21 2009
    2006 Audi A4 2.0T
    Stafford, Virginia
    02769 & 02770 Headlight Swivel Module Error
    2 Faults Found:
    02769 - Headlight Swivel Module; Left
    003 - Mechanical Failure - MIL ON
    Freeze Frame:
    Fault Status: 11100011
    Fault Priority: 2
    Fault Frequency: 237
    Reset counter: 40
    Time Indication: 0
    02770 - Headlight Swivel Module; Right
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 229
    Reset counter: 40
    Time Indication: 0
    My headlights are really off alignment, I throw those 2 codes above and when I go to adjust them using the manual adjustment screws the white screws just keep turning but the beam output does not move at all. I am not going to the dealer to fix this does anyone have any recommendations on what I should do?
    Thanks ahead of time
    Jun 21 2009
    2006 Audi A4 2.0T
    Stafford, Virginia
    bumpy bump
    Senior Member Two Rings STONER's Avatar
    Sep 02 2009
    B7 A4, B8.5 S4, A3 Tdi
    Layton/Utah
    Your computer has a set position on the headlights. You need to tell it your going to make adjustment to allow it too. As for your the faults. Looks like you might need replacements. Maybe.
    Oct 16 2008
    South Florida - Ft Lauderdale
    You have PM
    I will take a look and should be able to fix that
    phil
