Originally Posted by
Dolphin18T
Why are you guys going with the 044 over the 040? I would understand if it was less expensive, but I thought it was actually more expensive and it doesn't fit as nicely.
It fits just fine, identically to the 040 actually. They use the identical basket, you only have to file/grind down the little ring on the pump a little so it slides in to the basket. Not to much though so it fits in and holds tightly, then cut the bottom threaded piece off pump for if it was being ran inline so the pump will clear the filter on the bottom of the basket. That takes a few minutes and is simple, and it
IS less expensive going the 044 route and you have a much better pump for flow if you are planning on big power.
You can get an 044 for $170-$200 if you look around or buy from ebay. Then you have Pump Cradle part # 895 201 779 H $43.56 at Genuinevwaudiparts (listed as "resevoir") and Pump Strainer part# 895 201 531 A $53.24 at Genuinevwaudiparts leaving the need for the banjo fitting $10.99 Integrated Engineering and bolt $8.99 also at Integrated Engineering for top of pump and a inline check valve since you will be taking the one off the top of the pump and you can get one of those for cheap. All of that is under $350 and an 040 drop in for the B6 is $390-$400 from any of the popular vendors.
