Results 1 to 4 of 4
Thread: P0243
    Dec 24 2007
    St. Pete,FL
    P0243
    So I'm only running 3 lbs. of boost....I switched out the n75 and still nothing. While I did that I noticed the wire that goes to the n75 sits on above the turbo and is now brittle and frail. i believe this is prohibiting the signal to the n75 and wastegate isn't opening properly.(very frustrating) What do I do to go about fixing the problem/ how much should this repair set me back? Thanks in advance for any info, it's much appreciated.
    Dec 24 2007
    St. Pete,FL
    Bump... No one else has had this problem?
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Check to see if you are getting power to the N75. Unplug the connector to the N75. Use your multimeter to check voltage between terminal 1 on harness connector and ground. terminal 1 will be the one closest to the flat side of the connector. Hook up the meter and crank the car briefly. You should ~12v. If not you have a power supply problem. Just cut out and replace the damaged section of wiring.
    Dec 24 2007
    St. Pete,FL
    thanks for the info. what kind of wire do i need? could this also be leading to the battery light coming on sometimes and my one HID going out 30 second after i turn it on?
