Results 1 to 32 of 32
    Stage 3 Forum Advertiser Two Rings
    Aug 25 2010
    DC
    >>>***R.A.I. Motorsport: SNOW PERFORMANCE WATER/METH GROUP BUY!!***<<<
    The BEST bang for your buck on any turbo/supercharged engine!
    Most of you all already know what this is and what it does. Highly atomized water/methanol mix is injected into the air inlet tract to DRAMATICALLY cool air and raise the octane of the fuel mixture entering your engine.
    Simply put: YOU WILL GET MORE HORSEPOWER. YOU WILL GET MORE TORQUE. YOU WILL LOVE IT!
    On my personal turbo car i've seen an additional 7~10* or ignition timing at 25psi of boost.
    I want you all to reap this benefits so for a limited time only we are selling our Stage2 MAP kits at ROCK BOTTOM pricing! This is the LOWEST we are allowed to go.
    PRICE:
    $398.05(w/ BOOST based controller)
    $407.55(w/ MAF based controller)
    $685.00(Stage 3 kit W/advance boost AND injector duty referenced controller)
    So lets get it rocking with 10 people ready to make more power!
    1. Turbo_Joe :thumbup:
    2. Primetime
    3. .
    4. .
    5. .
    6. .
    7. .
    8. .
    9. .
    10. .
    As added bonuses, customers will receive:
    • One free nozzle bung for mounting to hose, aluminum, or steel piping!
    • FREE SHIPPING IN THE CONTINENTAL U.S.
    • 10% OFF Additional Accessories
    Active Member Four Rings
    Sep 11 2007
    Tampa, FL
    Already bought one for my S4 last time you guys ran this group buy, but I wouldnt mind a stage 2 for my mazdaspeed6
    Veteran Member Four Rings shorterthanrich's Avatar
    May 24 2009
    2000 S4 Nogaro Blue, 1996 Ford Exploder
    Boston
    Benefits of this over the VAST one?
    FREE BEER, click: Pintley - Tap Into Your Tastes!
    My iPhone/Android App
    2000 S4 Nogaro Blue DxC/BritishTurbo Stage GTX
    GTX2863 Build Thread - 575WHP
    Sep 27 2007
    00 S4 6sp, 06 Mazda3 HB Auto
    Columbia, SC
    this has the word "Snow" in it so it runs EVEN COOLER.
    Honestly I don't know...
    00 B5 S4 - K04, Stern Soft MM, Stern Snub, DTS, Neuspeed Rear Sway, Oinkies, GIAC stg 2 XR, Vogtland GT, SSAC copy. Soo... Stg 2.31456?
    06 Mazda3 - Wife's car and autox car
    96 Eclipse GSX - Gone
    03 Acura CL Type S - Gone
    96 Soarer GT - Gone
    93 RX7 R1 - Gone and missing her
    Active Member Two Rings BJ Thomas's Avatar
    Aug 26 2010
    2007 Audi Q7, 2001 A6 2.7T, 2006 KTM 625 SMC
    Northern Baltimore County MD
    Is this a dual nozzle set up like the VAST system so I can run it directly to my ARD bi pipes? What size nozzles are supplied wit the kit?
    Aug 25 2010
    DC
    Quote Originally Posted by *Blue-Angel* View Post
    Well then DO IT! :)
    Quote Originally Posted by shorterthanrich View Post
    I can't speak for VAST's product. I do have a couple friends that run theirs and it seems fine.
    I personally run a stage3 snow kit on my car and am very pleased with the quality of the components provided.
    Snow pumps operate at 170psi base and can push up to 250psi resulting in EXCELLENT atomization!
    Some Snow controllers utilize 2D mapping where they can reference two signals allowing for much more precise control on injection start point, partial spray amount, and full spray.
    For instance on my Stage3 kit it references boost and injector duty cycle. I can bias it to spray more when boost goes up or more injector duty goes up.
    A lifetime warranty for injection systems is available with exclusive use of Boost Juice™ injection fluid. The standard warranty is 2-years from purchase and covers all Snow Performance systems purchased on or after June 1,2009 manufactured by Snow Performance, Inc. (Snow). This warranty terminates when the original retail purchaser sells or otherwise transfers the product to any other person.
    In the end which ever kit you chose to go with you will get a great temperature decrease and a NICE octane increase that will leave you happy!
    Aug 25 2010
    DC
    Quote Originally Posted by BJ Thomas View Post
    yes, you tap your bi-pipes and voila. I would go with either two 175cc nozzles or if you know you'll be a little more aggressive with ignition timing/boost then two 225cc nozzles.
    Apr 05 2007
    Quote Originally Posted by [email protected]. View Post
    it says 'one free nozzle bung' - for us B5 owners needing the dual setup what's the 'final price'?
    Aug 25 2010
    DC
    $439.05
    Jun 24 2009
    Houston, TX
    $439.05
    It is $411.55 straight from the Snow Performance website with 2 nozzles with NO group buy special pricing...what gives?
    Senior Member Three Rings MTV2002's Avatar
    Jul 08 2009
    2000 Imola 6sp, 2001 Imola 6spd avant
    Del Aware
    what would you charge for you guys to install this?
    Veteran Member Four Rings Turbo Nerd's Avatar
    May 12 2009
    B5 A4, B5 S4, C5 Allroad, C5 A6
    Detroit Metro Area
    Quote Originally Posted by MTV2002 View Post
    Same question popped up in b8s4 section he said typically 425 IIRC
    Veteran Member Four Rings HotSauce's Avatar
    Jul 26 2004
    Madison
    This is a VERY easy DIY.
    Oct 05 2010
    York PA
    if anyone has any knowledge would it be worth it to spray water and meth if I ma running a Giac chip, intake, and uuc exhaust- also would I have to reprogram my ecu for the addition of the water and meth- or just spray and run the 100 octane program
    Veteran Member Three Rings Congratulati0ns's Avatar
    Nov 09 2009
    tri-state
    Would there be noticble diff to a stage 2 s4?
    6 Speed Single Turbo S4
    Q7 TDI S-Line
    Jul 26 2004
    Madison
    Upper two posts. Yes.
    Veteran Member Four Rings 97B518TQM's Avatar
    May 31 2009
    CA. USA
    Quote Originally Posted by seeya View Post
    Exactly. How is this a good deal or even close to being a "group buy price"???
    SOLD: B5 S4 Tial 770s with meth @652hp
    Current: C7 S6 - SRM +4mm RS turbos, SRM inlets, SRM fuel lines, DS1 stage 4 custom tune, HPFPs, X-pipe, H&R lowered
    Apr 05 2007
    Quote Originally Posted by 97B518TQM View Post
    only thing i can think is maybe RAI's $439 shipped is the same as Snow's $411+shipping. But then it's STILL not a group buy price...
    Aug 25 2010
    DC
    That does not include the dual nozzle upgrade kit (which includes: extra line, T-fitting, and nozzle holder) so you would be paying $441.55 from snow.
    $425
    Quote Originally Posted by WikiWiki View Post
    no you would not need to reprogram but you would be able to run the 100oct file
    Quote Originally Posted by Congratulati0ns View Post
    ABSOLUTELY
    Quote Originally Posted by exorcet View Post
    note: i said this is ROCK BOTTOM...that means it is MRP i am not allowed to sell/advertise for lower than that. As such we offered other incentives such and free parts, discounted parts, and free shipping. That's what makes this a deal.
    Nov 09 2009
    tri-state
    so if i have a revo sps3 and the 100oct file, thats all i need? how does it work with the whole spraying at certain boost levels or however the meth pump is programed? (sorry not familiar with water/meth)
    Q7 TDI S-Line
    Aug 25 2010
    DC
    You can get the boost based controller and set a start point (say 5psi) and then a FULL spray point (say 16psi) or you can get the MAF based controller which goes off of voltage instead.
    also additional pricing is up people...
    Aug 25 2010
    DC
    get some!
    Jun 24 2009
    Houston, TX
    [[email protected].;5764422]That does not include the dual nozzle upgrade kit (which includes: extra line, T-fitting, and nozzle holder) so you would be paying $441.55 from snow.
    IT says very specifically on their website that it is for our vehicle, when you add this option to the cart there are no options and it say it includes 2 nozzles and all hardware for installation...here is the link, please explain...
    http://www.snowperformance.net/product.php?pk=9
    Jun 22 2009
    Dundalk, MD
    What Q is saying is that for most people, *BUNGS* not nozzles are required for install. Some people with S4s may opt out of this, and I know we can accommodate you in another way. However, people with aluminum bi-pipes may want these as a free upgrade.
    You are correct that every kit comes with 2 nozzles
    Sep 11 2007
    Tampa, FL
    ^ Like me. Where my S4 has bungs already welded in place. But my MS6 needs a bung welded in place so I can mount the nozzle.
    Jun 24 2009
    Houston, TX
    gotcha! thanks for the clarification Clint! :)
    Aug 25 2010
    DC
    sorry for the confusion.
    Veteran Member Four Rings AAAA's Avatar
    Mar 05 2007
    German Crap
    Wake Forest, NC
    FAIL
    Prius' are GAY
    Aug 25 2010
    DC
    Quote Originally Posted by AAAA View Post
    FAIL
    shut your face Scott! lol
    Aug 25 2010
    DC
    group buy still in progress.
    Aug 25 2010
    DC
    upsies.
    Sep 11 2007
    Tampa, FL
    When more people join in Ill buy another meth kit from you guys. Just like I said before tho, will be for my mazdaspeed6. Single nozzle, 300+whp, tank in trunk so would need solenoid.
