Results 1 to 2 of 2
    Veteran Member Three Rings JStanger's Avatar
    Oct 06 2005
    02 Audi A4 3.0
    St. Petersburg, FL
    Flashing CEL - P0340
    I have an 02 A4 3.0 manual and I am getting a flashing CEL through the low RPM's and usually goes to solid around 3k. It stutters at idle and is very sluggish through the low RPM's. Performance is awful!! I had a P0340 code which is the cam sensor but my mechanic replaced it and it didn't fix the problem. I also have a few random misfire codes. What else could be causing this? Could it be bad coilpacks? I have around 120k miles on the car and I know they haven't been changed since I purchased the car with 48k miles.
    Thanks for your input!
    Veteran Member Four Rings A4Maine-iac's Avatar
    May 03 2010
    2012 TT Sold
    Maine
    Swap out 1 and 2 with 5 and 6.See whats up. Yeah i bet CP's are going. Also see if you have the old version. If so call a Dealership and replace for free.
    2002 A4 1.8T - sold
    2007 DTM S4 -Sold Sound clip - https://www.youtube.com/watch?v=bGz60n-31jc
    2012 TT - TTS Rear & Exhaust- UNI Stage 1+ " More to come"
    2021 SQ5 - " Just getting started
