Went to get flashed from Unitronic stage one to state two, using some tt225 injectors I got off the 'zine. Got flashed and car idled rough for 15 minutes then evened out. The tech took the car for a spin and noted misfires under load. I was asked to take the car for a spin and decide. I also experienced progressively worse misfires under load then all the time. I was okay for a few after clearing the codes but would always go back to that state.
Had the tech retune the car to original and he went from 2-->1+ first leaving the 386cc injectors installed but said it idled on two cylinders. So he swapped the stock ones back in and sent me on my way. I got about two kilometers away and the misfires returned, and retired me on the road. I tried swapping coil packs that vagd as misfiring. No help.
Came back to car first thing this AM found the car started up fine and drove it to a parking lot where I let it idle. Inside ten minutes it went to complete misfire chaos.
Tuner says it's my car's fueling system. I think it's the 1+ file, so I'm waiting on a tow. If it runs fine on a stage 1 tune he'll pay for the tow, else I'm on the hook. I drove in just fine, aside from a lean lambada reading coming from my test pipe.
Why's my car not taking to the 1+ file with my stock injectors??? It ran fine with them before I swapped anything.
Problem is I'm not in my city, was going on a backpacking trip, and am due back home to fly out to work Wednesday. So I definitely need a solution without paying a ton for diagnosis!
TIA, and tow is here!
