    Apr 09 2008
    B7 S4 Avant
    Los Angeles, CA
    4.2 Allroad Brakes DIY and Suspension question
    Searched for a brake DIY and didn't find one. Can someone point me in the right direction? Looking specifically for minimum rotor width. Also could use a recommendation for a good cheap source for rotors and pads.
    Also, I've seen a few posts on air ride suspensions failing and well, I think this car has a problem as well. The front left strut occasionally sags when left overnight. Starting the car brings it back to normal ride height but I also noticed when driving the nose of the car sometimes bobs up and down. Not knowing much about air ride suspensions, is there a single component that typically fails? Seems its leaking. Where can I find a good cheap replacement and is there a DIY for it?
    The manufacture date is 11/04.
    Thx!
    Veteran Member Four Rings MYDWAGON's Avatar
    Jul 08 2007
    Ohio
    You most likely have a bad air bag.Arnott Industries is the best place for replacement.How many miles?
    04 4.2 Allroad w/H-Sports-Full Tint-Armorcoat- RS6 Exhaust/Gutted Kitty-Flaps-Michelin Pilot Sport A/S Plus-Thule Box-OEM Trailer Hitch-226k
    Senior Member Three Rings MLFHNTR's Avatar
    May 29 2010
    '04 Allroad, '02 GTI
    Daytona Beach
    Here is the quick tell on the bags. Put soapy water on them and see if it bubble (like tyres) and if there is then the bag is bad.
    There is not really a cheap replacement cause the whole system is expensive but +1 for Arnott. They make some good stuff.
    There are a lot more AR guys on quattro world and there might me some more diy's/specs in their forums.
    2 Hooker Limit...
    Embry-Riddle European Car Club President
    Veteran Member Three Rings scot_w's Avatar
    Apr 05 2006
    '04 allroad 4.2, '00 A4 1.8T QWSM
    The allroad FAQ should answer a lot of questions.
    Stage 2 Banner Advertiser Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    Quote Originally Posted by SPhwoarr View Post
    Thx!
    HERE is a writeup on air spring replacements and I'll have a writeup on brakes by early next week.
    As for pads and rotors, are you looking for OEMish performance or maybe something more aggressive. Either way, take a look HERE and let me know if I can help in any way. If you do order, please use the coupon code in my sig.
    Hugh
    EuropaParts.com, Your Trusted Audi Parts Source
    Facebook: Like Us on Facebook
    Instagram: Follow Us on Instagram
