Results 1 to 21 of 21
    Oct 06 2008
    Los Angeles, CA
    My hood is EFFED UP!!! Please advise. (Pics)
    It looks like two people put a heavy box on my hood and slid it across to each other for a couple min. It is really unattractive. I can't take it. It's getting worse and worse. It started off in a small area and now it's just spreading around the whole hood as you can see.
    Is it the clear coat or the paint? And why did it start doing this? Do I have to get it repainted?
    Thanks
    Phone pics.
    Veteran Member Four Rings Valve_Cover's Avatar
    Aug 06 2009
    MKII GTI 20v Beast
    Qc
    most likely just the clear coat. give it a good compound and wax it'll be good as new
    I'm just here for the free coffee
    Oct 09 2008
    Can you feel it?
    The Awesome™
    Jul 28 2009
    2003 A4 3.0 V6
    SL,UT
    it looks like the hood has been re-painted and it is just a crappy paint job from maaco...
    Veteran Member Four Rings MikeWire's Avatar
    Mar 08 2007
    Air and water
    SATX
    It hard to tell from the pictures, but it almost looks like the clear coat is de-laminating. Like Josh said, can you feel it? Or is it under the surface? If it's on the surface you may be able to wet sand and buff the clear back into shape, but if not you are looking at a respray. Audi warranty probably won't cover it, but you may call AOA and see.
    Did you buy the car like this, or did it just start doing that? Any resprays or accidents?
    -Mike
    @countdowngarage
    2015 Porsche Macan S | 2021 Atlas SEL-P | 1972 VW Bus | 1965 VW Beetle
    SOLD - 2017 VW GTI APR Stage 2
    SOLD - 2001 Allroad - 6 speed swap thread
    SOLD - 2003 A4 1.8TQM Avant Atlas - 5 speed swap thread
    Veteran Member Four Rings FORCE_FED_DUB's Avatar
    Aug 10 2008
    Denver, Colorado
    Quote Originally Posted by MikeWire View Post
    they won't. only extended warranty to the surface finish is against rust perforation
    BT/BAT build threads make me happy I have a stock turbo
    -Cam
    Veteran Member Three Rings hotshot32890's Avatar
    Dec 05 2009
    2008 VW Passat. 2000 Audi S4
    Boston, MA
    wow man sorry to see, did you just come out and see your car like that? thats terrible.
    Current:
    IN THE MARKET
    Previous:
    F21 Brilliant black b5s4
    SRM K24 silver b5s4
    Black B5S4: Eurojet Grenade DVs, AWE Twin1
    Eclipse GSX: 16G turbo
    Veteran Member Three Rings Dirty's Avatar
    Feb 07 2008
    05 A4 1.8T 6spd Quattro
    Orlando, FL
    My Hood looks the same way
    15 S6 4.0T Quattro
    DS1 stg1//B.E. TCU Tune
    S4 Door Blades//CC'd S4 Bi-Xenon//AWE Boost Gauge//RS4 Rear Sway Bar//K&N filter//Forge 007 DV//12" Audibahn sub-1500w//ATP 3" TP//Hitachi "E" coil packs//Revo Stage 2//FMIC & PS cooler//S6 LED's//RS style fog grills//Hawk HPS Pads//Tein SS Coilovers//19x10 et35f/et25r Rotifrom MIA's//Falken 235/35
    Oct 06 2008
    Los Angeles, CA
    Can you feel it?
    It's just really rough, and feels like a shit ton of scratches.
    Maybe the previous owner got it repainted or something? I don't know why he would though because the car has a clean record. I'm puzzled.
    When I bought the car the paint looked brand new all around. I bought it at an actual Audi dealer with CPO, but it's not valid anymore. This started happening probably about 10k-15k miles ago, and it just keeps getting worse. I haven't gotten anything resprayed and no accidents.
    I should definitely give it a shot.
    I'll take pics with a digi cam and post them so you guys can get a cleaner look at it. The top of the trunk is starting to do the same thing, but it's in the beginning stages. Besides that, the sides, roof and rear look pristine.
    Jul 28 2009
    2003 A4 3.0 V6
    SL,UT
    Quote Originally Posted by hotshot32890 View Post
    really?
    Oct 06 2008
    Los Angeles, CA
    DAMNIT!! There goes that plan. lol
    Nope, it started out as a little spot that looked like scratches and progressed into what you see now.
    Any suggestions on a good compound and wax?
    Whoa! Forreal?? Was your hood ever repainted or anything before?
    Jan 24 2008
    Pennsylvania
    Quote Originally Posted by JEENYUS View Post
    ^exactly what i thought. how long have you owned your car? knowledge of any possible paintwork?
    that sucks man. id try reviving it for a day with some good meguires polish and wax to see what that gets you. hope thats all it is.
    if you decide to have it repainted, do alot of searching for a shop and discuss the materials and process with the shop so you know what you are getting. it almost makes no sense to have cheap paintwork done if you intend to keep your car. lots of things, some that look somewhat like this, can happen in a short period of time with cheap paint work.
    Oct 06 2008
    Los Angeles, CA
    I've owned it for about 2.5 years and never have I gotten any type of paintwork done.
    I will give it a shot.
    Advice well taken, thank you.
    Feb 07 2008
    Orlando, FL
    Quote Originally Posted by R3K8C24 View Post
    Not that I know of. I think mine is a little more cloudy/hazy. I tried buffing it out by hand a few weekends ago, I think it just made it worse. I'm going to get the car detail and see if they can get it out or I may just go buy a power buffer. idk yet.
    15 S6 4.0T Quattro
    Veteran Member Four Rings ocod's Avatar
    Feb 17 2009
    05 A4 1.8TQM, 05 Nissan Xterra, 99 Sea Doo Sportster
    miami
    very fine grit. can't make it worse
    KO4 APR Stage II+ // tt injectors // Podi SW gague // NGK BRK 7E .28 gap // 2.5" Test Pipe // Forge 007 DV //
    APIKOL Snub Mount // Stock N75 // 20%Tint // DTH FRP Skirts // 270 miles to empty // B7 key fob // 35W 5K HID's
    Oct 06 2008
    Los Angeles, CA
    Thought of an idea and need some feedback.
    Would it look dumb if I just got the hood vinyl wrapped? rather than going through this process of trying to sand and buff?
    Apr 12 2009
    I would say thats a repaint with in compatable materials, looks like the clear and the paint are disbonding and the clear is checking, detailing isn't going to solve it, the only way to fix might be a full respray with proper products. You say the boot lid is starting to do the same thing?, then who's to say what other panels are going to do it. You also stated the car had a clean bill of health,with no prior accidents that you know of? When I bought mine it passed with flying colors with no sign of any previous damage but I could tell through experience that the back corner had been resprayed, it wasn't until I removed the tail light that you could see the over spray.
    Stage 2 Banner Advertiser Four Rings Matt@EuropaParts's Avatar
    Dec 22 2009
    Piscataway, NJ
    It looks like a Delorean
    But seriously, take it to a body shop...they might be able to spray some clear and buff it out
    Matt
    EuropaParts.com, Your Trusted Audi & VW Parts Source
    Phone: 201.777.0005
    Email: [email protected]
    Twitter: Specials & Discounts
    Oct 06 2008
    Los Angeles, CA
    Yeah the boot lid is starting to do the same thing, but it's in the beginning stages where you can see light scratching, but not nearly as bad as my hood. That's exactly how my hood started out. Maybe my panels will start doing it as well one day, but as of now they are as smooth and shiny as a brand new car.
    According to the carfax it had a clean bill of health. I bought it at an Audi dealer, and since I've bought the car, I haven't been in any accidents.
    So do you guys think it would look dumb if I just got it vinyl wrapped instead of getting it repainted?
    Apr 12 2009
    Just like I said mine didn't have any hits on the carfax either but I know what to look for and it was repainted in the back pass corner, and when I removed the tail light it was evident that it was re sprayed, so it might have been fixed on the side and never reported so it didnt make the carfax. Same might have happened to your, maybe it was vandalized previously and the owner had a " buddy that knows how to paint " and they resprayed in a driveway or something without proper prep and products. I'm just speculating though. Take it to a proper prof. detailer and get their opinion, and then take it to a proper body shop and see what they say.
    Mar 17 2008
    Its funny how people think that when carfax is clean car was not in any accident. To tell you the truth many salvage cars are in better condition then clean title cars because they have to pass inspection.
    I have seen clean title cars in which people have died... they are fixed and sold as "no accident" clean history.
    Anyways. Your hood was probably repainted and if that white stuff is on the surface you can try to buff it, if you get some good results but not 100%, wetsand with 2500 grid and buff again. Otherwise hood has to be repainted.
    Good Luck
