Results 1 to 40 of 46
    Veteran Member Four Rings Trigger Happy's Avatar
    Jun 17 2008
    2K S4
    Rockville, MD
    These damn tierod ends won't come off!
    Ok so I'm doing the outters for my front end and cannot get the drivers-side tierod off. In the picture below I broke bolt 1 free, and took bolts 2 and 3 off completely. For nut 3 the center shaft that the nut comes off is still in there, but I don't see how you would take that out. I've soaked it in PB and banged the hell out of it but its not coming off. It does move up and down, just gets stuck before it will slide all the way down. Any helpful tips?
    UPDATE: I got it our of the knuckle, but now I can't get the end to unscrew from the tie-rod. Follow-up question is it possible to remove the entire assembly without the special audi tool?
    UPDATE#2: The end now just spins on the threaded shaft that attaches the end to the rod.
    "Clearly, a liger is not as practical as a Katana. S4s can't carry ligers. fucking 500lb cat in my backseat using my alcantara as a scratch post for its HUGE FUCKING CLAWS? I dont' think so bro"
    Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall and torque is how far you take the wall with you.
    Jun 17 2008
    2K S4
    Rockville, MD
    This is where I'm at now
    Veteran Member Four Rings seanj130's Avatar
    Sep 05 2008
    Pittsford, NY
    I think you have to punch that bolt out, then get a ball joint separator. or just beat down on it with a hammer, i think i used heat.
    Best regards,
    Sean.
    Paying someone to install parts and bragging about it being fast, is like watching someone
    bang your wife and being proud to raise their kids.
    Jun 17 2008
    2K S4
    Rockville, MD
    Quote Originally Posted by seanj130 View Post
    Have a ball joint separator, used it and it just gets stuck in this position.
    Sep 05 2008
    Pittsford, NY
    try a big pry bar. like a really long handle flat head.. did you ever slide that bolt out?
    Best regards,
    Sean.
    Registered User Four Rings CDesign's Avatar
    Jun 10 2009
    West Coast
    place a longer bolt on the top of the bolt joint and use a hammer to punch it out.
    Jun 17 2008
    2K S4
    Rockville, MD
    Quote Originally Posted by CDesign View Post
    Just tried using an extension and it doesn't budge past where it is in the picture. I can almost move it up and down within the knuckle by hand, it just won't go any further down. Does that stud bolt thing need to come out?
    Jan 29 2007
    08 S4 00 S4
    MD
    Yes it needs to come out. Try to take the load off of the tie rod ball joint and the retaining bolt by first making sure the tie rod is seated correctly. Then hit that bolt with a BFH and be ready to replace it.
    08 S4- Stock SOLD
    Jun 10 2009
    West Coast
    Quote Originally Posted by Trigger Happy View Post
    Yes, that's the pinch bolt.
    Account Terminated Four Rings
    Oct 26 2009
    Beaver Creek, CO
    From what I've done with a B6 you need to remove the bolt that has the threads facing you in the picture. There's a groove in the tie rod that that bolt sits through to lock everything in place.
    That's on my B6 though, so I can't comment if that's the same on a B5.
    Oct 26 2009
    Beaver Creek, CO
    Observe..
    With that bolt out it should drop right out.
    Jun 17 2008
    2K S4
    Rockville, MD
    Sweet thanks guys
    Oct 26 2009
    Beaver Creek, CO
    Sweet thanks guys
    Let us know if that works. I want to not feel super dumb with our cars (if this is right).
    Veteran Member Four Rings s2the4's Avatar
    Nov 02 2006
    01 Stage 3 S4 Silvaro, 01 S4 Avant Nogaro
    Western Mass
    When you say hammer you are using a mini 3lb sledge hammer right? not a carpenters hammer? the stud that is starring you in the face needs to come out to allow the knuckle to fully open so that the tapered part of the tie rod (that is still in there) can have enough clearance to come out! hope that helps!
    |MRC-Tuned Stage 3| | RS4 K04 Turbos | | RS4 Y-Pipe | | RS4 Airbox | | RS4 Fuel Pump | | 60lb Siemens injectors | | ER SMIC | | APR Bi-Pipe | | All JHM Goodies | Vogtland GT | | Porsche 993 TT Brakes | | 034 Motor & Trans Mounts|
    ...For now
    417whp @ KTR Ayer, MA 110 octane with open dumps
    clicky
    Jun 17 2008
    2K S4
    Rockville, MD
    Ok got the pinch bolt out and now I can't get the end off the rod.
    Jun 17 2008
    2K S4
    Rockville, MD
    Quote Originally Posted by s2the4 View Post
    I actually used a carpenters hammer. It came out with one medium hit. I just wasn't sure if that came out or not so I didn't wanna force it and break anything.
    Oct 26 2009
    Beaver Creek, CO
    So I know what I'm talking about for once?
    Jun 17 2008
    2K S4
    Rockville, MD
    Quote Originally Posted by Greedo View Post
    Haha yep seems like it.
    Oct 26 2009
    Beaver Creek, CO
    I feel spefial!
    Veteran Member Three Rings gmann's Avatar
    Jan 12 2008
    illegals and moonshine stills
    Under busted VW's/Audis, OH
    Observe..
    Please GOD tell me you don't PRY between the slots to try to remove the TRE and Control arms?!
    Active Member Four Rings
    Sep 11 2007
    Tampa, FL
    Yes I'm sure they have. Ever arm I've come across shows evidance that the slots have been expanded and are now mishaped.
    Oct 26 2009
    Beaver Creek, CO
    Quote Originally Posted by gmann View Post
    I didn't, I just knew of that pic for a good reference.
    Jan 12 2008
    That's a BAAAAAAD picture though. Puts horrible thoughts into peoples minds that don't know any better. My butthole puckers every time I see a pry bar shoved into the gap in a steering knuckle like that.
    Established Member Two Rings AJ88CAB's Avatar
    Oct 04 2006
    Atlanta, GA
    Its possible that the "banging" deformed the slot on the TRE shaft and it will not clear the pinch bolt bore. Push it up and look in the pinch bolt hole so you can see the slot. I bet the top side is expanded from the banging. It is a tight fit and if you were able to move the TRE shaft as much as you did in your first picture you probably deformed the slot. The top of the shaft has a hex head, put a hex wrench on it and try turning it and see if you can position it somehow that it will come out. If it is deformed too much the only other idea I have is use a small file in the pinch bolt hole to file the deformed edge of the slot enough that it will pass. Sometimes a BFH is not the answer:)
    Good luck!
    aj88cab
    Marietta, GA
    2002 Audi S4, Silver, 6 Speed
    1988 Porsche 911 Cab
    1972 Porsche 914 (long term...really long term...restoration project)
    Oct 26 2009
    Beaver Creek, CO
    Haha. I understand. I just put a bar between the end and the arm and had to gently pry it out. Never had any issues and usually once I got it to pop down a little I could just pull it out.
    Jun 17 2008
    2K S4
    Rockville, MD
    Quote Originally Posted by AJ88CAB View Post
    Good luck!
    The tie-rod end is out of the knuckle, I can't get the end off the tie rod now. I'm following this DIY. It says that it just unscrews, I just can't seem to get leverage on it. Does anyone know if its possible to remove the entire tie-rod assembly without the special Audi tool? I have the full tie rod assemblys from fcp and would like to replace the entire thing while I'm in there.
    Active Member Two Rings BJ Thomas's Avatar
    Aug 26 2010
    2007 Audi Q7, 2001 A6 2.7T, 2006 KTM 625 SMC
    Northern Baltimore County MD
    if I am understanding you correctly your saying the outer tie rod is seized to the inner tie rod. If that is the case you need to cut the outer off at the jam nut with a cut off wheel and then you can remove the boot covering the inner tie rod from the power steering rack. You can then see the inner tie rod. You will need a inner tie rod tool to remove it. I have one at work (I am an Audi tech) I can snap a picture of tomorrow for you. You may be able to rent one from Autozone or some other parts store. This is the easiest way to do this job when you have a seized outer tie rod end to the inner tie rod. I have done this job more then 100 times at the dealer and this is the most efficent way to do this job. I hope this helps you. Let me know if you need a picture of the tool.
    Apr 26 2009
    2000 Audi S4, 2003 BMW M3
    Melbourne, Florida
    try a gear puller...worked like a charm along with, letting some pb blaster sit for a few minutes
    -Zach Zimmer
    Veteran Member Three Rings Dubluv11's Avatar
    Jan 08 2010
    00 S4
    Quote Originally Posted by BJ Thomas View Post
    you could use this special tool... or a really big adjustable wrench... and if you dont have an adjustable wrench you could simply just use a plumbers pipe wrench like i did hahaha... just be careful not to let the wrench slip and round the head of the inner tie rod or else you'll never get it off
    but ya...those tie rod ends that go into the knuckle... the pinch bolt needs to be fully removed because if you look at the tie rod end...its got a groove in it where the part of the pinch bolt that is not threaded sits...to lock the tie rod end in place... therefore it MUST come out...just for future reference
    Jun 17 2008
    2K S4
    Rockville, MD
    Quote Originally Posted by Dubluv11 View Post
    Where exactly do you put the wrench to take the tierod off? Mine just turns freely.
    Jan 08 2010
    00 S4
    well see it should thread into the steering rack via a huge nut like thing...
    http://www.034motorsport.com/oe-part...r-p-17928.html
    enlarge the image on that page... the part on the inner tie rod that threads into the steering rack... you have to crack that loose to remove the entire inner tie rod from the rack... and just thread the new one back on and crank it down nice and snug... i obviously didnt use a torque wrench for that part so i just cranked it on there nice and tight
    Oct 04 2006
    Atlanta, GA
    Please use two wrenches to counter hold the steering rack shaft.
    If you just twist on the inner tie rod you can tweek the steering rack seal. You REALLY don't want to do that! See picture for what I mean.
    [IMG][/IMG]
    aj88cab
    Marietta, GA
    Jun 17 2008
    2K S4
    Rockville, MD
    So the end broke free from the threaded shaft that screws into the rod. I really hate this car sometimes.
    Veteran Member Four Rings belinko's Avatar
    May 09 2005
    Audi 1.8T QM
    Encinitas, CA
    It's easiest to just replace the entire TRE assembly (inner and outer).
    The control arm replacement is a bitch if it hasn't been done in a long time or if there is excessive corrosion.
    1.8L, JE pistions, IE rods, APR stg3+, GT28 Turbo, Setrab, ER comp. FMIC, APR HFC, Milltek Cat-back, APR 91, 93, 100 - CM FX 300, CM 240 LWFL, JHM 4:1, AMS SS, RS4 Motor Mounts - 355mm Alcon 4 pot, 300mm Alcon S4 - Stasis/Ohlins MS, Hotchkis Front and Rear, Stern adj. CA Front, 034 adj. CA Rear - 18x8.5" Work CR Kai wheels, NT-01 & Dunlop Z1 star spec - RS4 Front bumper and grill, Tow Strap, RS4 E-codes - SPA Technique Dual Digital gauges Oil & Water temp, Oil & Boost pressure, RS4 Door Handles
    Veteran Member Three Rings rarak69's Avatar
    Jul 15 2007
    Snap-On
    Pittsburgh, PA
    Wow, this is like a 20 minute job. I take it you dont work on cars much?
    put the tie rod back into the nuckle, throw a screw in it to hold it. There that will hold the TRE while you throw a large wrench on the jamb nut. use PB blaster if you still have issues.
    do not use any heat near or around the boot, it can melt it, then youll be replacing that, and its a little bit of a pain as the inner clips are hard to tighten down with rack bolted in.
    Jun 17 2008
    2K S4
    Rockville, MD
    Quote Originally Posted by rarak69 View Post
    This is my first car and I haven't been working on cars for very long. I'm pretty mechanically inclined, I'm just at school working out of a toolbox in my trunk, in the parking lot of my apartment complex. I'm also deftly afraid to break anything, especially bolts, as this is my DD and the wait time for an order around here is about a week.
    Jul 15 2007
    Snap-On
    Pittsburgh, PA
    ha been there before. just do what i said, ive done countless TRE's this way, never had a problem getting them off, and i live on the east coast as well.
    Veteran Member Four Rings S4evr's Avatar
    Mar 07 2007
    Belmont, MA
    I'm bringing this back because I am having a hell of a time getting the pinch bolt out in order to drop the tierod end out of the upright.
    the pinch bolt nut is off, but the pinch bolt itself is corroded in place it seems. I have soaked the bitch in PB for a few hours, several minutes with my snap on air hammer, and also a BFH. The pinch bolt will not move. Any bright ideas?
    ThorTechnik.com
    Active Member Four Rings aysix's Avatar
    Feb 06 2012
    Las Vegas
    Quote Originally Posted by S4evr View Post
    Same boat as you. I'm wondering how you got the air tool in that tight space? Maybe your nut is on the other side where the end of my bolt is.
    Veteran Member Four Rings Timtheguru's Avatar
    Dec 30 2009
    Try to spin that bolt with a wrench on it. Once you can spin it, it will come out.
    2001.5 S4 Sedan
    2002 A4 Avant 1.8t - Traded in
    2001.5 A4 1.8t - Sold for $5
    2013 Q7 TDI Premium Plus (RIP, rear ended and totaled, assholes)
    2013 Q7 TDI Prestige S-Line
    2018 Q5 2.0t
    2022 e-Tron Chronos Edition
