Results 1 to 14 of 14
    Dec 05 2009
    New York
    help - tiny oil leak pass side
    I have a silver dollar size oil leak that accumulates after I take my car out for a drive. The leak is coming down on the passenger side, if you drew a straight line to the ground from between the + and - battery terminals, just behind the front axle.. TIA
    Veteran Member Four Rings Timtheguru's Avatar
    Dec 30 2009
    VCG, Cam Chain Tensioner, or Cam plug.
    Dec 05 2009
    New York
    i mean, the location of the puddle is on the ground if you drew an imaginary line going through the center of the battery; if it was coming from the areas you mentioned, i should be able to located the leak coming down the block? I don't see any oil coming from the top side of the engine
    Dec 30 2009
    Have you looked underneath (looking up at the engine) where the puddle is forming? If you don't see any oil running down the engine from underneath then maybe it's a oil line for the turbo?? Try to locate the leak.
    Dec 05 2009
    New York
    alright, got the car up on jacks, here is a picture, it is coming down the rear side of this
    Dec 30 2009
    Seems like the transmission is leaking, maybe the fill bolt is leaking? I haven't experienced a leaking transmission casing yet.. so I'm not much help here.. Good luck, I hope someone else will chime in here!
    Senior Member Two Rings nycion's Avatar
    Nov 30 2009
    AVWDIS
    Empire State
    Check is your oil filter is tight. Grab the filter and rotate your hand on it - see if there's any oil on your palm...
    Dec 05 2009
    New York
    Quote Originally Posted by Timtheguru View Post
    i think you are on to something regarding the transmission, i re-torqued the bolts on the ATF pan as there was a TSB 37-06-08. I have a feeling that may not resolve it. Anyone have tip knowledge that might have a suggestion?
    Veteran Member Four Rings 1sadavant's Avatar
    Jun 21 2005
    '01.5 S4 & '05.5 M3
    Murrysville, PA
    Quote Originally Posted by nycion View Post
    You obviously do not know where the oil filter is...
    OP: Have you a 6spd or automatic? Are you definite it is engine oil or could it be transmission fluid or brake fluid (slave cylinder). Although you insist that it is dropping between the +/- terminals of the battery, fluid can drop anywhere by traveling along the hoses or other structures.
    2001.5 Audi S4 6spd ASP Stg 3 Imola
    IG: dr.yellowbird
    Dec 05 2009
    New York
    Quote Originally Posted by 1sadavant View Post
    Auto (flamesuit on), It may be tranny fluid - it smells and looks like oil but smells stronger. The tranny fluid was just changed out along with the TC about 5 months ago
    Veteran Member Three Rings Dubluv11's Avatar
    Jan 08 2010
    00 S4
    Quote Originally Posted by bps4 View Post
    check the turbo return line going back into the block on the passengers side.. same sorta thing happened to me and when i got in there there was ZERO o-ring in there.. they like to wither away over time... if thats not it then maybe its an oil line going to the turbo?
    Dec 05 2009
    New York
    Quote Originally Posted by Dubluv11 View Post
    sorry for the stupid question, do you have to remove anything to get to the turbo return line?
    Jan 08 2010
    00 S4
    well... you should be able to see it on the rear side of the block closest to the firewall... you should see 2 stainless steel braided oil lines that run to the turbos. one on the drivers side and one on the passengers side.. i believe :S.. i dont know about the one on the pass side but on the drivers side it was a BITCH to get to... they are allen key bolts IIRC and it was really difficult to squeeze any tools in there but i did it without taking anything off.. i'm not sure about on a TIP trans though
    Dec 05 2009
    New York
    do you get at them from the top side or underneath the car?
