Results 1 to 32 of 32
    Mar 17 2008
    Catalyst System; Bank 1: Efficiency Below Threshold/ DIAGNOSTICATOR + OLD GUY help:(
    About 25-30k miles ago i had this code "16804: which is Catalyst System; Bank 1: Efficiency Below Threshold.
    I have diagnosed the problem and it turned out to be fuel filter. I put new fuel filter and the car came to life and code disappeared.
    About 5k miles ago i got the code again. I have inspected the exhaust system for any leaks and intake system but couldnt find anything. I also changed air-filter to high flow AFE filter.
    My car is 2005 1.8t 6spd with 60k miles.
    Code comes back every 60-100 miles and check engine light goes on and stays on.
    Thanks for help.
    Veteran Member Three Rings spyder101's Avatar
    Jan 25 2009
    some where in the U.S.
    You need a new cat conv.
    Oct 09 2008
    You need to replace the cat. Or you could buy a HFC or a test pipe.
    The Awesome™
    Mar 17 2008
    How do you know its a cat ?
    Like i said i had this code before and the other time it turned out to be fuel filter.
    If it is cat, is it something thats covered in CT under emissions law ?
    Thanks
    Oct 09 2008
    Well if the cat is bad you have a federal warrenty of of 80,000 miles and something like 8 years.
    The Awesome™
    Mar 17 2008
    Is there any way to check if it cat ? I have vag-com if that helps.
    Veteran Member Three Rings A4.Rob's Avatar
    Sep 02 2009
    Toronto, Ontario
    yeah po420 is the Catalyst System; Bank 1: Efficiency Below Threshold code
    thats what i had (issue is bad catalytic converter 100%) I got a used cat from here from a user for about $100. Got that installed, cel is gone and its good as new.
    2003 Audi A4 1.8TQM
    Mar 17 2008
    Kind of weird for cat to fail at 60k miles ? Also would i have to pay anything for dealer to diagnose this problem ?
    Also my car has salvage title would that affect the federal warranty ?
    Sep 02 2009
    Toronto, Ontario
    Yeah that is strange. Mine failed just over the warranty at around 85k, so Audi wouldn't do anything for me. Since your at 60k and with in the warranty, I'm pretty sure that everything will be free regarding it even the diagnose. But if its not a cat issue they might make you pay, I'm not sure. I'd say best bet is to call the dealer tomorrow, tell them the situation and see what they say. If they give you any weird info, call AOA.
    I dunno about the salvage title affecting it.
    2003 Audi A4 1.8TQM
    Jan 25 2009
    Quote Originally Posted by Antekaudi View Post
    No, it's common. yes, you will have to pay diagnosis. Dont' know about the salvage title situation.
    Mar 17 2008
    Interesting, will call audi tmr.
    I still wanna find out how to further diagnose this issue myself. I hve vag-com so i can take some readings for you guys.
    Sep 02 2009
    Toronto, Ontario
    that code means faulty cat. I dont think you need to diagnose it any more.
    2003 Audi A4 1.8TQM
    Mar 17 2008
    Last time i thought its a bad cat too and that was when my car had 30k miles, it was fuel filter. Anyone knows why fuel filter would affect that ?
    Veteran Member Three Rings Gmoney's Avatar
    Jul 29 2009
    05 Audi A4TQM
    Charleston, SC
    My cat went at about 60k. Audi diagnosed it for free but I had to go twice. Basically they just had to read the code and then clear it and if it came back then it was bad. It was covered under the federal 80k or 8 years warranty.
    APR stage 2+, CM FX400, LWFW, APR snub mount, JHM short throw, RAI TP, Forge DV, RS4 rear sway bar, Vogtland Coilovers, Thor belly pan. 19's staggered.
    Sep 02 2009
    Toronto, Ontario
    um it obviously wasn't the fuel filter if the code came back........
    also sometimes when cats are failing they can be intermittent and the cel will go off and on untill it finally fails which it probably has now.
    2003 Audi A4 1.8TQM
    Mar 17 2008
    Interesting, kind of weird that code went away for 30k miles and cat failed at 30k. My car has 60k right now. I will call dealer tmr and see what they say.
    My car had bad coilpack once and i drove it for few miles, maybe thats what killed the cat.
    Senior Member Two Rings Audituning02's Avatar
    May 13 2008
    2002 A4 1.8T 5QM 00 Rover Discovery 2
    Maine
    I have 116k on the clock and the same thing going on. I get a MIL and read the code its a p0420 which is cat efficiency below threshhold. I too cleared the code and it comes back about every 100 miles or so, sometimes more sometimes less. I unplugged the first o2 sensor ahead of the cat and ran a meter through it to check the efficiency. It came back that there was no restriction. Indicating the cat is still intact, yet I still have the code so I believe the cat flow meter to be inaccurrate and I am quite confident I need to replace the cat soon.
    Audituning02
    Magnaflow : TP : tt 225 DV : Color Matched Lowers :
    Pearl Black Roof : USP Front : RS6 19s : Sport Suspension : Smoked Lamps : Dice Link : Black Out Grilles : 35% Tint : Rear Lip Spoiler : ZiZa Yellow Fogs : B6 S4 Front Brake's
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    It isn't all that unusual to get a P0420 and have it go away after a few hot/cold drive cycles. Cat monitoring isn't a continuous process. The ECU performs a diagnostic at different intervals depending upon certain conditions in the drive cycle and if the efficiency is out of range you get a CEL. If the catalytic converter passes several subsequent test cycles the ECU will turn the CEL off. As the cat deteriorates the CEL will present itself more often until it just stays on all the time. If you are under 80K miles/8 years it should be covered under a federally mandated emissions warranty.
    Aug 26 2005
    Besides a failing cat, the DTC can also be caused by a bad post O2 sensor, However, a second DTC for the sensor itself usually is set when that is the issue, but not always.
    Vorsprung durch Technik
    Mar 17 2008
    The post o2 sensor is the one after the cat right ?
    When i first got the code when my car had about 30k miles i replaced that o2 sensor thinking it was it. But it wasnt, and i still cant explain why fuel filter replacement fixed the issue for 30k miles. Could be something with the connection to ecu ? Because of all the humid etc?
    any other ideas ?
    Dec 28 2006
    Western Maryland
    any other ideas ?
    That is correct, the post O2 sensor is the one on the outflow end of the cat. As I mentioned earlier the ECU runs a diagnostic test on the cat at different intervals under different conditions. It's very possible that your clogged fuel filter was causing your car to lean out and consequently the rear sensor didn't see what it expected to see on one of its diagnostic checks and threw the P0420. As long as the cat passed the next several diagnostic tests the ECU turned off the CEL. Your issue now is probably a deteriorating cat.
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    will a o2 spacer resolve the CEL?
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by widgget View Post
    Sometimes it will sometimes it won't. Just have to try it and see. However, if the OP is under 80k miles he should see about getting it covered under warranty.
    Dec 18 2007
    nj
    i asked because i just started seeing this after replacing the rear O2 sensor on my 5spd. it's over 80k so i'm trying to find a cheap way out and it needs to be inspected by the 23rd.
    guess i'll give the spacer a try.
    thought about swapping the HFC from the tiptronic for a few days to get the inspection done but thats allot of work and it might still throw a CEL (doesn't on the tiptoninic but isn't that written out in Revo S3 sofwtare?)
    Senior Member Two Rings bigdadi's Avatar
    Oct 07 2010
    2012 A4 Quattro Tiptronic 2.0T
    Boston MA USA
    Istall a Mini cat cel fix betweem post O2 sensor and the CAT may stop the cel light. The post O2 sensor won't see HC & NOx so it won't throw a code.
    www.bigdaddiesgarage.com
    This won't fix O2 sensor though if sensor is bad. The sensor has to be on woring condition.
    12 A4 Quat 2.0T,
    02 A6 AvtQtr 3.0 (Sold),
    07 Subaru Outback LTD (Sold)
    Veteran Member Three Rings kt883's Avatar
    Nov 10 2010
    Stoney Creek
    it was likely never the fuel filter but that probably improved the performance a bit and you deleted the codes so the cat code only comes sporadically. I think your holding to much value to that notion that the fuel filter is the problem.
    Senior Member Three Rings blownb6's Avatar
    Apr 08 2012
    Ontario
    Quote Originally Posted by kt883 View Post
    4 yrs late
    Mar 17 2008
    Sweet necro-bump.
    Anyways, the issue was the catalytic converter itself. I ended up putting 034 HFC.
    The stock cat separated inside and was moving around, one time it would line up in and not throw a code and others it would fall out of place and throw a code.
    The car has now 140k miles and never been better :)
    Veteran Member Four Rings Knives1010's Avatar
    Mar 17 2014
    2006 Dodge Charger SE, 96 K2500 Suburban
    Tacoma, Wa
    Nice to have a resolution to the problem at least
    Oscar "The Grouch": Is now dead thanks to a drunk driver RIP
    Apr 07 2011
    That's awesome that the OP replied 4 years later! Props to you OP and like Knives said, it's good to have a resolution.
    Nov 11 2010
    Rochester, MN
    Props? Hell, the OP should be tarred and feathered and run out of town on a rail for making us wait 4 years to find out the resolution!
    19" B8 S5 Peelers
    Mar 17 2014
    Tacoma, Wa
    Argh if you think that then I'm scared to see what you would do to an OP who doesn't post a resolution
