Results 1 to 7 of 7
    Established Member Two Rings ptowndvldg's Avatar
    Apr 13 2010
    2001 S4 Vast stage 3+
    Portland, OR
    will these fueling parts work for me?
    I have aquired pretty much everything for my stage 3 2000 s4 6mt build except for fueling/tune.. so its a stage 3 car running on stock programing with nothing done to the fueling. Anything you can do has pretty much been done (its a k04 car).. would these parts work for me and would any of the tunes (awe,vast,jhm,apr,etc.) work for me with them?
    Im debating picking these up from someone but am not completely positive it will be a good buy. still a debate on what injectors to use too. thanks for the help
    90mm MAF housing plus adapter
    3bar FPR
    Hitachi MAF Pigtail w labeled wires
    Hitachi Mass Airflow Meter
    RS4 accordian hose
    Jun 14 2007
    2000 S4
    Connecticut
    I wouldn't just pick up a 90mm MAF housing for K04s... 85 is a better choice. I'm running a 90mm on a VAST tune, but it's completely custom and I don't think many customers are running the setup I have because 90mm is way too big for K04s.
    Apr 13 2010
    Portland, OR
    cool thanks, what about everything else?
    Veteran Member Four Rings 97B518TQM's Avatar
    May 31 2009
    CA. USA
    So you are thinking if you should buy the stuff the guy is selling in the classifieds. I would first pick the tuner and then go with what they require. 90mm Maf housing is too big indeed for K04s. You will need the Hitachi maf though, as far as I remember, so you can get the maf sensor with the wiring. The rest of the stuff, not really. You could get the RS4 accordion and hope you will find an RS4 maf housing to go with it but then you would need an RS4 box.
    SOLD: B5 S4 Tial 770s with meth @652hp
    Current: C7 S6 - SRM +4mm RS turbos, SRM inlets, SRM fuel lines, DS1 stage 4 custom tune, HPFPs, X-pipe, H&R lowered
    Veteran Member Four Rings BlkdoutS4's Avatar
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    i'm running a 90mm MAF on my JHM stage 3 with K04s... car runs really well.
    '01.5 Silver B5 S4 - Follow my build here: http://www.audizine.com/forum/showth...4-Build-Thread
    Apr 13 2010
    Portland, OR
    ive wanted to get the tune first but havent found any a-box's for sale as of late
    Active Member Two Rings noxplode's Avatar
    Sep 01 2010
    encinitas
    My car is an a box like yours and to use the hitachi stuff you end up essentialy converting to an m box. Was looking at thisstuff as well and after talking to a few peole the diameter of the maf housing is critical to the tune. Guy is askin fair prices though you need that pigtail and hitachi maf to get the sensor out of then go with whatever company you go with requires. Hope that helps good luck
