I didn't change my front main seal when doing my timing belts about 30K ago, and now I have a decent sized oil leak that I having a sneaking hunch on it being from the front crank/main seal.
When I did the timing belt I did the VC Gasket, and the cam timing chain tension gasket, so I don't attribute it to that.
The leak is on the bottom end, I am thinking I can narrow it down to the front main seal, the rear main seal before the tip, and maybe the oil pan gasket.
What are the common areas where seals tend to go? The car has 120K on it now. Between oil consumption and oil leaks I am having to top off with a quart 3K miles into my 5K oil change interval.
If I do have to take the timing belt to get to the front main, is there a source for buying the tools? I used Blauparts and their timing belt tool rental the last time around, but they will only rent it to you with a timing belt kit purchase. I really don't want to purchase a whole new kit with only 30K since the last timing belt job.
I would prefer to get the proper tools and not jury rig the timing belt installation, or removing the old seal and installing/pressing in the new one.
