Results 1 to 3 of 3
    May 12 2009
    2006 A4 2.0T Quattro Avant, 2010 Mazda5 GT
    Calgary, Alberta, Canada
    Anyone running MK2 TT wheels?
    I found a deal on some lightly used 18" MK2 TT wheels.
    I've searched around and can't seem to find any information or pictures of anyone running MK2 TT wheels on either a B6 or B7. I know the bolt pattern is 5x112, the seller claims the offset is 40, the wheels are these:
    Anyone know if there'd be fitment issues? The tires are 245/40's so unless I replace the tires the speedo will be about 1.5% off, but I'm sure I could live with that until I got around to changing the tires.
    Veteran Member Four Rings yung turbo's Avatar
    Feb 19 2008
    2005 A4 1.8TQtip-2011 A4 2.0tQAuto
    NYC/DE
    you should be good with 245s especially because the offset is 40 unless your dumped then you might have an issue. Our stock offsets are 45
    TuRboK1ng
    You Are All Witnesses
    And The Yankees WIIIIIIIIIIIIIIIIIIIIIIIIIIN
    The Yankeeeeeeeeeeeees WIIIIIN!!!!!!!!
    Veteran Member Four Rings A6.S-line's Avatar
    Nov 29 2008
    NYC and NJ
    IIRC the offset is 50 or 52 mm, and just as important the width is 9". Use one of those online offset calculators to see where they clear vs your current setup.
