Results 1 to 38 of 38
    Sep 09 2010
    Värmdö Stockholm Sweden
    What to do next... (Tuning)
    I have GIAC stage 1 chip right now and i think it works like an charm, but you get used to the extra hp fast and want more :-)
    So Whats next...
    Im thinking of bigger injectors (tt 225 ones) and upgrading to Stage 1.5 or FX as GIAC calls it...
    But i dont know if thats the next to do...
    I have stock exhaust, cat and downpipe and not sure if i need to change that first...
    If im looking for hp the Cat (200cells) and Downpipe is more prioritated then the cat-back, or am i wrong now?
    After that a FMIC, progressiv fuel pressureregulator, and well as the last thing an bigger turbo...
    What do you think?
    Go with Cat (200cells) and Downpipe or Injectors and chip upgrade as next thing?
    Best Regards
    Lars
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Your best bang for the buck would be to go straight to the FX file with the bigger injectors. It will provide a very nice torque increase and it will work fine with the stock exhaust. I would recommend upgrading the intercooler next followed by the exhaust. Otherwise you will heat soak very quickly in the warmer weather. No need to change the fuel pressure regulator since you don’t have one anyway. The returnless fuel system pressure is regulated by a constant pressure valve in the fuel filter.
    I ran the GIAC –FX with a stock exhaust and stock intercooler. I have since upgraded both the intercooler and exhaust. The intercooler made a bigger difference than the exhaust; however I still have a stock cat. I suspect the high flow cat would also make a noticeable difference.
    Sep 09 2010
    Nice nice :-)
    Do you know if i can just upgrade the chip (map it) i got for a lower cost or must i buy a hole new "chip"
    I know there is 2 seperate files but do you think thay can work of the stage 1 raw file and just map it for the new injectors?
    Dec 28 2006
    Western Maryland
    I don't know how it works in Stockholm, but in the States the chip upgrade from 1 to 1+ is free. Or at least it was in 2006 when I upgraded mine.
    Sep 09 2010
    ok then i hope its free here too... Sure I will accept the cost for the work of the upgrade time and the change of the injectors, but the program itself would be nice if its free
    Veteran Member Four Rings El_Chapusca's Avatar
    Jun 06 2008
    Long Island, NY
    -Joey aka Chappy
    GCC Law/Rule #22 Enforcer.
    GCC: Its Serious Business
    Tastefully Modded
    Sep 09 2010
    checked with GIAC and the update file itself is still free
    Veteran Member Four Rings BASARAB's Avatar
    Mar 01 2010
    Farmington Hills,Mi
    Which intercooler did u use? Do u have a "clicky click" by any chance? :)
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by BASARAB View Post
    I am running a TyrolSport SMIC. It's about as big as you can go and still fit in the OEM location. If I recall it has about 360 cubic inches of volume which is pretty hefty for a SMIC. Can't seem to get a clicky from my work computer. Too many filters. Just go to Tyrolsport.com and you can find it.
    Edit: Made correction on volume.
    Veteran Member Four Rings jonan's Avatar
    Nov 25 2006
    2X B7 RS4 - STG III B6 A4 (gone, but still in the family) - Mini R56 S - '15 Macan S - 997.1
    Austin, TX
    Quote Originally Posted by El_Chapusca View Post
    you sir, have made the post of the day...
    Want my guns??? ΜΟΛΩΝ ΛΑΒΕ!!!
    B6 Mods:
    Fully Built Motor w/ GT2860RS and all supporting mods : My Build Thread
    RS4 Mods (sprint):
    RNS-e MKII : ECS SS : JHM Spacers : Deflapped IM : UM Tune : KW V3s : Tubi Rumore : Hotchkiss F&R SBs : 034 Diff Inserts : Phil Special Headlights w/ STI Lenses : 10 Layers : Spare 07BNS (#masterrace) : Apikol Diff & Trans Mount
    Senior Member Three Rings jettman's Avatar
    Feb 27 2006
    punta cana, dominican republic
    good info
    Kiss the rings bitch
    Dec 28 2006
    Western Maryland
    LOL!!!!! Funny stuff El_Chapusca!! At work all I saw was a red X and I wondered what the pic was all about. Imagine my surprise when I got home and opened the thread. Thanks for the vote of confidence. I try to help when I feel I have something to contribute.
    BASARAB: Here is a little more info on the TyrolSport SMIC. It might dispel some of the bias against a decent SMIC. .Clicky click Also, I checked the dimensions and the volume for the TyrolSport B6 SMIC is 360 cubic inches. Certainly a larger FMIC will perform better but size for size the SMIC will hold its own.
    Cheers!
    Dec 28 2008
    That's good to know about the Tyrolsport unit. Always considered it but was nervous it might not really do the job.
    Sep 09 2010
    Checked with my tuner and they did not think the FX stage was worth it now... maybe efter DP, cat, exhust, FMIC and turbo...
    I think its an good stage cus the parts aint expensive... but my tuner wants about 450$ for just the labor... update the chip and installing the injectors...
    Just the labor...
    so with the injectors + shipping + labor i would pay around a little more then 800$
    What do you think of that?
    I mean i could easely install the injectors myself... its almost plug and play... and even update the software if i had it and the program to update...
    The problem is that the injectors must be installed at the same time as I update the software... cant be doen before or after cus i have to drive about 70km to the tuning shop...
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Quote Originally Posted by Le31504 View Post
    Just the labor...
    the labor should be free..but even if not it takes less than an hour to upload the new software.
    the injectors should take about 30 minutes to install and is an easy DIY. search for a good one and go for it
    2019 SQ5 Prestige
    Sep 09 2010
    Yes i know its easy and should not take 2 hours to install the injectors... but that is what they charge...
    Sure i could park outside their parking and change them before... but it dosent feel that nice standing outside and doing that by my self...
    Sep 09 2010
    What could happen if i drive like 50miles with too large injectors?
    Can my engine or cat get damage in some way? limp?
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    You can also use the cheaper Genisis 380cc injectors for cheaper, they are approved and I used them fine with my FX program. The next step with GIAC is the GT28R kit from AWE, pricey but a solid kit as it is what I run. You would definatly need all the supporting mods for it though and it comes with a HFC. PSI is working on a even better kit but haven't seen retail on it.
    Mar 01 2010
    Farmington Hills,Mi
    It takes less than 10 min to re-install injectors. Remove and put back your regular injectors at home, so u get familiar with the process and than its gonna be easy to do it on the parking lot near your tuner shop.
    Established Member Two Rings VegasUSP's Avatar
    Apr 21 2010
    North Las Vegas
    Quote Originally Posted by pondside36 View Post
    Where did you see this? I tried searching for it but I couldn't find any info on it.
    Mar 01 2010
    Farmington Hills,Mi
    Quote Originally Posted by VegasUSP View Post
    http://www.ecodetuning.com/shop/cart..._detail&p=1229, but I suggest this http://www.ecodetuning.com/shop/cart...t_detail&p=564
    Apr 21 2010
    North Las Vegas
    Oh I thought he was saying PSI had a new turbo kit in the works. I already have the TT injectors i'm just trying to plan out my turbo upgrade the GTRS is the leading candidate.
    Active Member Two Rings DeepCover's Avatar
    Mar 23 2010
    B6 A4 USP 1.8TQ 6MT; B5 A4 2.8Q 5MT Sport
    Portsmouth, NH
    I installed my Test Pipe (gutted cat) one weekend then the next week installed my TT225 injectors, drove 12 miles to my tuner without incident. The new file took care of the Check Engine Light and there was no issue driving with the larger injectors.
    2004 A4 1.8TQ 6MT | Ultra Sport Package
    Sep 09 2010
    i have heard that some get problems with non TT225 injectors... like the White/gray Bosch ones...
    I heard of idle issues and so on...
    So i rather go with the OEM TT injectors
    I will try to install them outside the tuningshop then... shouldnt be that hard to do... just the weather and wind that buggs me... :-)
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Here:
    http://www.audizine.com/forum/showth...epts+3071R+kit
    and here:
    .....and then a correction, you could go with the AWE K04 with GIAC as well, then the GT28R Kit
    Sep 09 2010
    Are there any diffrence between the 06A 906 031 J and 06A 906 031 BC injectors from bosch?
    Will both work?
    Apr 21 2010
    North Las Vegas
    Here:
    and here:
    Wow!!! That is a beastly kit too much power for my stock internals...
    Sep 09 2010
    Besides the new injectors do i need anyting more?
    Retaining Clips?
    Injector Inserts? whatever that is?
    http://www.ecstuning.com/Audi-B6_A4-...ectors/ES5289/
    Dec 28 2006
    Western Maryland
    You do not need to replace the injector seats. You can reuse the retaining clips, although it would be nice to have a few spares in case you drop one.
    Sep 09 2010
    ok :-)
    One more... I planing on cleaning around the injectors prior to the change... its kind of dirty... and i dont want any debris or dirt inside the intake or injector seat
    Can i use like crc quickleen on the intake and around the injectors... whipe of a little and then wash away the rests with water? (not on electrics.. i know!)
    Or can it cause the O-rings on the injectors to start leaking?
    Dec 28 2006
    Western Maryland
    That would work just fine. Spray it on and wipe it off.
    Sep 09 2010
    ok that sounds grate!
    Sep 09 2010
    Btw.. how do I know if i need to change the Injector seats?
    Dec 28 2006
    Western Maryland
    If they appear to be cracked. Honestly, I have newer heard of anyone having to change them out unless they were using the early APR injectors.
    Sep 09 2010
    ok good to hear :-)
    What injector did APR use?
    Dec 28 2006
    Western Maryland
    ok good to hear :-)
    APR used to use their own proprietary injector. It required removing, threading and replacing the injector seats. I don't know if APR still uses these. Clicky click
    Sep 09 2010
    ooh ok...
    That sounded advanced...changing to an new seats and retapping the threads...
    Mar 27 2005
    The Cold North
    With regard to the 1+ software setups APR has gone back to just recommending the OEM TT386cc injector. Works well in all conditions and is easier to source than those oeversized injectors they were allowing as an option.
    2001 A4 1.8TQM (in pieces..)
    2020 Chevy AEV ZR2
