Originally Posted by
flynnr
side mounts in our cars are WAY better than front mounts... the reason for this is that there isnt a radiator 1/4" behind the smic like there is with the fmic. the air flow then is increased greatly.
You forgot to mention the fender liner which is completely closed.
Radiator that's designed for airflow vs Completely closed fender liner. You decide which has more airflow.
However, you can get S4 fender liners. But still doesn't help with the physical size of a SMIC.
For reference:
I have a 50trim .48a/r and a Precision (600hp) intercooler iirc its around $350 +piping. The hot side is untouchable after a few runs, while the cold side is room temp. By few runs I mean, Full throttle 3rd gear redline, full stop, check logs/tune, full throttle 3rd gear redline, check logs/tune (repeat more than 20times). Full stop meaning no time for the intercooler to cooldown.
And my boost still comes at around 3800rpm.
SMIC = Will never be large enough to eliminate/reduce heatsoak
FMIC = Only limited by how much you want to trim your bumper
**** In the end, the main benefit of a FMIC is heatsoak, which only happens after a few runs ****
Most dyno logs have cool down between runs so intercooler efficiency is only measured by flow, not heat soak resistance.
