Results 1 to 6 of 6
    Veteran Member Four Rings event's Avatar
    Jun 21 2009
    OR
    AWE FMIC fitment help
    I just got mine and tried installing but my crash bar will not bolt back up, it rides against the IC and there is significant gap on both ends where it's supposed to mate to the car. The IC is nearly flush against the condenser except for the small gap at the top from the hangers and on the bottom from the foam inserts that are provided by AWE to prevent the IC from banging against the condenser.
    What's going on here? Is there a difference between crash bars, or are they possibly adjustable (there are bolts behind the end caps) and the gap for mine was shortened?
    Deactivated Four Rings
    Apr 09 2008
    Willow Grove, PA
    Quote Originally Posted by event View Post
    event,
    I got your pm but wanted to respond here as well.
    Do you have any pictures of these issues that you can send me? My email is [email protected].
    I'll pm you further instructions on how to proceed.
    Oct 20 2008
    Denver
    I had the same issue. one side of the crash bar would fit over the FMIC but the other side would just not fit at all because of the size of the IC. After about an hour of frustration I ended up just running it w/o the crash bar. Sorry man. hope you find a solution that I can use!
    Jun 21 2009
    OR
    Quote Originally Posted by Alex/A.W.E. View Post
    I will get pics, had to get the car assembled enough to go to work.
    Quote Originally Posted by AudiTFSI3o3 View Post
    That's exactly what's happening. If I actually settle the crash bar perfectly flat/flush against the FMIC there is equal gap between each mounting bracket coming out the rear of the crash bar and the chassis where the bolt holes are.
    Oct 03 2008
    93 White NX2000, 2005.5 B7
    Lancaster, PA
    I didn't have any fitment issues....only power steering fluid everywhere...lol...good luck with the install...I'm sure AWE will will you out...
    Oct 20 2008
    Denver
    I was about to hammer in the crashbar - the points where the crashbar comes into contact with the sides of the IC. it might work
