Results 1 to 6 of 6
    Established Member Two Rings leoj's Avatar
    Aug 09 2010
    99 santorin a4 2.8 quattro
    British Columbia Canada
    cabin filter location ? smell
    hey just did an engine wash the other day ,my motor looks nice and clean but now everytime i use my heat or ac my car smells like nasty engine wash ! just wanted to know if anyone has any idea how to fix this situation the right way besides hey get an air freshener lol ,,,and also wear the cabin air filter is located on a 99, 2.8l , thanks for the help
    Veteran Member Four Rings 99blueb5's Avatar
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    if its facelift (99.5) or up then there is kind of a flap piece over by the pass. window tray, if its pre face lift then the filter is under the whole plastic trim which is held in with one screw and two plastic type locking screws, very easy, dont cut your hand on the plastic though!
    99 A4 1.8TQM:
    APR Stage 3 GT28rs kit, CM FX400 6puck, 3" downpipe, Nuespeed catback,Nuespeed short shift, Cxracing fmic, Forge007 DV, H&R coilovers, APR snub mount, gasket ported head, VDO guages, e codes, 6k's, Fiberimages CF hood/trunk, A8 BBK, IE Rods
    00 B5 S4
    Vast stage 3, Rs4 airbox, ko4's,borla cat back, neuspeed sways, statis coils, jhm fmic, SSAC Dp's
    Aug 09 2010
    thanks ! any pics to show were that is im a bit lost ? my a4 is a 99 btw
    Nov 23 2005
    Woodbury, CT
    I found this picture. The filter is basically below the red circle in this picture:
    99.5 1.8TQ
    Aug 09 2010
    thats what i was looking for ! thanks alot
    Sep 17 2010
    gso via avl NC
    if you want to try and get the smell out faster go and get some BG frigifesh and spray the new filter with it when you put it in. this will get pulled thru the HVAC system and get that smell out faster.
    here is a place that sells it. whenever i install a new cabin air filter on a customers car at work i always spray it down with this stuff 1st.
    http://www.ac-evaporator-cleaner.com...esh-single.htm
    B5 A4 Avant 1.8tqm_________MKIII GTI 2.0
