Yesterday I got a CEL, pulled the code:
16725/P0341 Camshaft Position Sensor (G40) Implausible Signal - Intermittent
I thought maybe my timing might be off, so I lined it up at TDC, pulled the valve cover both camshaft sprockets are spot on, and 16 teeth between on the chain. I just did a new timing belt about a month ago, got it from ECS in their kit (153 tooth belt).
So I thought maybe the sensor was going bad, it was still running good, until today, it died under about 5# of boost, and then when I tried to start it it just cranked but wouldn't start.
Could a bad CMP sensor keep a car from not starting? Wondering if there is another unknown issue.
