Results 1 to 7 of 7
Thread: heat wraping
    Jul 23 2010
    heat wraping
    00 a4 quattro manual
    how much of the exhaust should i heat wrap/ is it worth it?
    Established Member Two Rings xRAYx's Avatar
    May 30 2010
    Chanhassen/MN
    most of the test pipe/downpipe.
    Senior Member Three Rings b5a4gt28's Avatar
    Oct 15 2007
    97 B5 BAT A4 2.0 HTA30R, 01 STG 3 S4, 04 B6 A4
    Telford Pa
    25ft should be good.
    A4-Full-race mani, HTA 30R, Built 2.0L, AEB head, 034 IIc, 3658's, ID1000's, JM fabrications, etc...
    S4-034 tuned, 034x intake, BW K04's, OEM RS4 Goodies, EV14's, APR bi-pipe, Apikol mounts, AWE everything else.
    Jul 23 2010
    awesome, thanks guys!
    Jul 11 2008
    Vail, Co
    I would not heat wrap if you are in an area that you will get a lot of moisture behind the heat wrap as it will corrode the metal
    Veteran Member Three Rings dowsett6's Avatar
    Sep 10 2008
    99.5 1.8t BT, 97 1.8t
    Ontario
    Quote Originally Posted by flandog View Post
    yet should burn off since the exhaust is hot???
    Active Member One Ring FormerA4Owner's Avatar
    Nov 01 2010
    Central FL
    Quote Originally Posted by dowsett6 View Post
    Yes and no. If the car is parked there is still going to be moisture and condensation build up, during driving I hope there isn't any moisture. Heat wrap on a down pipe that is in the engine bay isn't that bad when you are needing a component shielded from the heat directly. Custom downpipes on big turbo setups sometimes are way too close to other parts in the engine bay. If you need things shielded then do it, if not, I wouldn't.
