Results 1 to 16 of 16
    Veteran Member Four Rings csosnowski's Avatar
    Sep 05 2010
    Computers
    Terrebonne, Oregon
    So I just installed my new APR Snub Mount
    As the title reads, last night I installed my new APR Snubber. 39 bucks from the local dealer, plus the parts old timer graciously price matched ECS for the oil sensor, +1 for my local stealership.
    Anyhow, the car feels better now. But, I noticed when I get on the brakes hard I can feel the driveline shift under the car. It makes sort of a pop or clunk. Then when I start moving again it levels out and I hear a corresponding pop or clunk when the drivetrain settles.
    I would like to get rid of this annoying (and probably not good) sound / problem. Which mounts should I be looking at to alleviate this issue? Motor, trans, both? DTS? Keep in mind that Im a poor college student and my wife questions every purchase I make for this money pit (LOL).
    I would love nothing more to put street density mounts and a DTS on it right now, but finances are a bit prohibitive so its the process of elimination for now.
    Thanks in advance for any input!
    2001.5 S4 Avant Sport 6MT - Brilliant Black - Nogaro Alacantra - SOLD
    2003 RS6 - Avus Silver - Black / CF - RIP
    2013 Q5 2.0t - Black - Black - RIP
    2004 A4 USP Avant 1.8t 6MT - Silver - Black cloth
    Senior Member Two Rings marioss4's Avatar
    Jan 18 2010
    bay area
    i did my tranny mounts and it has similar sound it was like clunkly suspension i tought but that took care of the probelms but thats my car you might need motor and trans mount and well a dts dosnt hurt i have one on my car
    Mar 18 2010
    Ottawa
    DTS = wifey says NO!!
    Mounts on the tranny she might go for, IF you pitch the DTS first!!.....
    Good luck, I am in a similar situation....
    Sep 05 2010
    Computers
    Terrebonne, Oregon
    LOL, that is a good idea in fact!
    I think ill try that...
    Veteran Member Four Rings odhinnhrafn's Avatar
    Jun 25 2010
    '01 Audi S4, '15 Chevy Colorado
    Reno, NV
    Also, look at gettin an upgraded rear diff carrier, like the one 034 offers. Should help reduce driveline slop as well.
    Nov 16 2009
    2001 Audi S4, 2003 Jeep Wrangler, 1988 Nissan 300ZX
    CO
    The apikol rear differential mount + carrier bushings can really tighten up the drive train also. There's a lot of reviews and info out there if you search. I recently upgraded all my mounts in addition to the apikol rear diff mount and bushings and I only noticed a small increase in cabin vibration. I'm expecting it to settle over time, so I'll let everyone know what I think after some added mileage.
    2001 Allroad - stage III+
    2001 S4 - was stage II+, meow totalled, but on its way to stage IV & WB
    2003 Wrangler Rubicon
    1988 300ZX Turbo
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Most likely your clunk / pop is the center diff mount. As earlier stated get the apikol poly mount. I bet that will fix it.
    Veteran Member Four Rings BITRBO's Avatar
    Mar 08 2007
    Mr. Worl-Wye
    Quote Originally Posted by BRSFour View Post
    I just got these two, but have only installed the diff mount so far... I just gotta find a small press to put those carrier bushings in and I can try it out Oh, and I have had the APR snub and AWE DTS on for a while now, and they definitely helped a lot (although I couldn't get the DTS poly mount to fit, so I'm only running the stock mount for now. Hopefully all of this will tighten everything up nicely w/o too much cabin vibration!
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
    Sep 05 2010
    Computers
    Terrebonne, Oregon
    So maybe I should look at a center diff mount instead of trans mounts then? Or should I do the trans then the diff mounts?
    Im not too concerned with cabin vibrations, its still pretty stock so its not too loud. Lots of rubber in the suspension still, lol.
    Active Member Three Rings
    Jan 15 2009
    2001.5 audi s4 stage 3
    pennsylvania
    if you do that snub do the motor mounts too.i mad the mistake of not doing them all and the snub made it much stiffer so my mounts blew out in 15 minutes
    Veteran Member Four Rings Dutchsider's Avatar
    Aug 19 2010
    NEPA
    Quote Originally Posted by marioss4 View Post
    This is a raping of the english language. I figured someone driving an S4 would have better grammar than this.
    My opinion, get the diff mount, go from there.
    Veteran Member Four Rings 97B518TQM's Avatar
    May 31 2009
    CA. USA
    Quote Originally Posted by Dutchsider View Post
    Don't forget most people driving B5 S4s are kids nowdays. These cars got so cheap even the illiterate can afford them :)
    SOLD: B5 S4 Tial 770s with meth @652hp
    Current: C7 S6 - SRM +4mm RS turbos, SRM inlets, SRM fuel lines, DS1 stage 4 custom tune, HPFPs, X-pipe, H&R lowered
    Veteran Member Three Rings Avant Fetish's Avatar
    Nov 13 2008
    Mk7 GTI / 8P A3
    So Cal
    Mine is making the same "pop" under accel.
    Is this the correct part? http://www.avalonmotorsports.com/ind...roducts_id=168
    Pic taken from this thread on AW
    http://forums.audiworld.com/showthread.php?t=341763
    Is there a less "pricey" alternative?
    Cup | Corrado | Cervelo S2 | Banshee Spitfire | Evil Following
    Aug 19 2010
    NEPA
    Yes, that's the correct part. ^
    Quote Originally Posted by 97B518TQM View Post
    True, it's still better than the MKIII Golf/Jetta (Vortex) forum
    Nov 16 2009
    CO
    Quote Originally Posted by BITRBO View Post
    In my opinion, the stiffer carrier bushings are just as important as the upgraded diff mount, mainly due to the similar stiffness of the diff mount (especially in a high mileage vehicle). You don't even need a press to install the bushings... Just burn the old bushings out using a torch (be careful not to burn the carrier bracket) and the slip the blue inserts into the bracket followed by the center sleeve. Be sure to lube the bushings very well and let us know how the ride feels before and after the install.
    I installed them over a month ago (800 miles since) and I've noticed that although the new setup had increased cabin vibration at first, it has since decreased to a little more than stock. Also installed Stern motor and transmission mounts, DTS, Apikol rear diff mount and carrier bushings and already had the 034 snub with cage. The drive train feels locked down, no more clunk.
    1988 300ZX Turbo
    Mar 08 2007
    Mr. Worl-Wye
    Sorry, I should've clarified that I have the 034 carrier bushings (street), not the Apikol ones... They're rubber and appear to have some kind of metal sleeve on the outside, so I'm thinking I might need to press them in, or at the very least heat up the diff carrier a bit to get them in.
    '13 C63 AMG -
    '14 Tiguan - sold
    '09 JSW - sold
    '04 GTI - sold
    '01 S4 - sold
