Results 1 to 21 of 21
    Active Member One Ring rickiwithani's Avatar
    Apr 11 2009
    Audi A4 3.0 b6
    Salt Lake City
    both my cats failed what are my options on a very tight budget
    I just moved from Philadelphia to Salt Lake City Utah and during the long trip my clutch went and the check engine light came on. which turned out to be my catalytic converter. So right now I'm looking for the cheapest option that will turn off and keep my check engine light off. the car is in the shop in salt lake now getting a new clutch and flywheel. Its a 2003 a4 3.0 quattro and both cats are shot whats my cheapest option to get rid of the Check engine light and keep it off? i would love to gain the hp by using a cat delete pipe but how do you keep the check engine light off.
    any links showing me where i can buy the piece would be helpful.
    also i have never done any exaust work on any car how hard is this going to be to do on my own?
    Veteran Member Three Rings android3000's Avatar
    May 28 2009
    '04 1.8t USP 6mt
    Knoxville, TN
    How many miles does the car have? If it's under 80,000 it's under warranty
    -Andrew
    Frankenturbo/GIAC
    Apr 11 2009
    Audi A4 3.0 b6
    Salt Lake City
    like 105000 so thats no good
    Senior Member Four Rings spector's Avatar
    Sep 08 2009
    SE
    Quote Originally Posted by rickiwithani View Post
    Look at 034's website for their HFC. I'm not sure if that works for a 3.0 though. You will need software to prevent a CEL from a TP/HFC, and I'm not sure who would make that for a 3.0.
    Good luck.
    Jun 30 2008
    Erie, Pennsylvania
    Is the cat clogging up or is it just throwing the code?
    If the only problem is the efficiency code, just use 02 sensor spacers on both rear O2's and be done. That is the same solution that people with test pipes or High Flow Cat's use to keep the CEL off. It's a cheap fix, so it's worth a shot. You can get the things on ebay real cheap, or use the non-foulers with some modification.
    Veteran Member Four Rings jonan's Avatar
    Nov 25 2006
    2X B7 RS4 - STG III B6 A4 (gone, but still in the family) - Mini R56 S - '15 Macan S - 997.1
    Austin, TX
    isn't the federal warranty like unlimited miles for 7 years? you just have to pay a $75 ded to audi to have them reset the light, if the CEL pops again you get a free cat, at least that's how the process worked for me...
    Want my guns??? ΜΟΛΩΝ ΛΑΒΕ!!!
    B6 Mods:
    Fully Built Motor w/ GT2860RS and all supporting mods : My Build Thread
    RS4 Mods (sprint):
    RNS-e MKII : ECS SS : JHM Spacers : Deflapped IM : UM Tune : KW V3s : Tubi Rumore : Hotchkiss F&R SBs : 034 Diff Inserts : Phil Special Headlights w/ STI Lenses : 10 Layers : Spare 07BNS (#masterrace) : Apikol Diff & Trans Mount
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    Federal warranty is 8yrs/80000mi, so he's past that. The cheapest solution would be the O2 spacer that someone mentioned above. After it's installed, clear the CEL and it should hopefully go away. Other options would be getting new cats, which would likely be a few hundred dollars at the least, up to $2000 or so for OEM replacements (if you're doing both).
    Senior Member Two Rings SEATONE's Avatar
    Jan 14 2010
    2000 Buick LeSabre Custom
    VINELAND, NEW JERSEY
    Gut them itches,,, I did... FREEEEEE!!!!! but lots of work.
    Seat
    SSSHHHHWWWWWWWWWWWWWWWWW
    Revo Stage 2, AEB IM and HEAD, Ebay FMIC, PCV and Vacuum Simplification, Samco DV, 2.5" TEST PIPE, TechTonics Tuning 2.5" DP, Custom 2.5" DP back Exhaust, 380cc Siemens Inj., Phenolic IMS, FRANKENTURBO F4H, ARP Head Studs, LOWERD 2IN., MORE ON THE WAY.....
    Apr 05 2009
    1984 Audi 4000S Quattro, 1989 Toyota MR2 SC, 1960 Alfa Spider
    SF BayArea
    http://www.walkerexhaust.com/product..._catalytic.asp
    call them and see what they offer for your car. they are a better quality aftermarket converter.
    Sep 23 2010
    SL,UT
    I live in salt lake our towards the Larry h miller track. Just cut your cats if there the problem we don't have emissions out in tooele county.
    Senior Member Three Rings JeffM03's Avatar
    Dec 30 2009
    Waterbury, VT
    O2 spacers work wonders. Got them on both my cats and haven't seen a CEL about them since.
    It's a pretty simple install, it's just a pain getting your hand down behind the engine.
    -Have couple extensions,pivots, and also an O2 Lambda socket
    -For the driver side O2 your gonna need to move the coolant tank out of the way.
    -For the passenger side O2 you'll need to remove the MAF.
    Denim Blue 3.0L V6 Quattro Tiptronic || I jury-rig everything.
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    could just be the sensor, what was the exact error? mine was reporting an open circuit i believe.
    Stage 2 Banner Advertiser Four Rings Matt@EuropaParts's Avatar
    Dec 22 2009
    Piscataway, NJ
    Cheapest way will be O2 sensors. If the cat actually crapped out, it would be b/t $800-1000/per side to fix (at least that's what a friend of mine paid to have his replaced)
    Matt
    EuropaParts.com, Your Trusted Audi & VW Parts Source
    Phone: 201.777.0005
    Email: [email protected]
    Twitter: Specials & Discounts
    Apr 11 2009
    Audi A4 3.0 b6
    Salt Lake City
    that seems to be the play i don't think they are clogged so all i need to do is take out the o2 sensors and replace them with sensor spacers. is there any thing else i need to do to keep the cel off
    Apr 11 2009
    Audi A4 3.0 b6
    Salt Lake City
    http://cgi.ebay.com/ebaymotors/Oxyge...ht_3261wt_1165
    is this what i need?
    how hard are they to install and how many do i need
    Jun 22 2009
    Dundalk, MD
    We have the j-pipes on our site, they have proven to be the best option for us
    Apr 11 2009
    Audi A4 3.0 b6
    Salt Lake City
    whats the site
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    whats the site
    Click
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Jun 23 2010
    Davenport/Iowa
    cats suck get rid of em
    Senior Member Two Rings jdigga99's Avatar
    May 13 2010
    BMW 330i
    Katy, TX
    Quote Originally Posted by kwimberly View Post
    LOL nice......
    2014 Lexus GS3350 F-sport
    2014 Audi SQ5
    "I'm in a silver bullet, caviar in the guts. 4 rings in her nose, a 3.0 on her butt..."
    Audi 3.0 group |VMR 19" 708's| Adam's Rotors - Race F&R| - SOLD
    Veteran Member Four Rings EErie B6's Avatar
    May 30 2008
    Honda HRX
    Penna.
    Quote Originally Posted by SEATONE View Post
    I wonder how much power can be had on the 3.0 by doing this. =/
