Here goes a killer multi-quote
Originally Posted by
bigern45
and going 3.0 is tempting, but im not sure if the cost and end result would be worth it.
The cost would be approx the same as building the heads. If I stay 2.7 I'm already paying for rings, crank bearings, cylinder hone, and balancing the rotating assembly anyways, so the only cost differential to go 3.0l is to find a 3.0l crank and buy pistons. So consider it about the same cost as building the heads in my case.
bigern45
so i know if i ever did a build more than what i have, i wouldnt bore or stroke the car. maybe 2.8, but thats just playing with inside parts, not removing any of this beautiful iron that makes this engine so strong, which in turn, could do away with a lot of reliability issues.
I'm personally not worried about the strength of block from boring it out. Rather the reliability factor I'm worried about has to do with the 3.0l pistons and rings. I've heard of some motors that burn an appreciable amount of oil. I'd hate to burn oil, lose compression, or have to rebuild anytime in the near future. I'm building it so that it doesn't need another rebuild for 100k+ mi of daily driving, like the stock engine.
bigern45
.. hell mike, you're the one that got me into all of this shit in the first place. when you sold me your crap, i wish you woulda told me " it isnt going to end here".. lol.. at least i would be prepared..
Well I did expect you to be satisfied running the RS6's for a little more than a year ha, but I think you got the better deal of that considering you've actually been driving your car for the past year and a half. I'm just hoping for myself that it does end here as far as B5 GT builds are concerned lol.
NogaroAvant
Going 3.0L is definitely not a necessity. AMD and EPL have proved that with their numerous TiAL cars running in the 600whp range. Honestly they have proved that stock pistons and headbolts might be the way to go. On thing you do see them doing is 2.8L heads with ported bowls and supporting valvetrain upgrades...
True. WMS' red car was a 2.8l w/ worked heads too. Def something to think about.
NogaroAvant
If I were building a daily GT car, I would go with stock bore/stock pistons and build the 2.8L heads with gasket matched and ported bowls. Power is all in the heads and stroke. Since you won't be stroking the motor, the head work will be key!
I won't be porting the heads much, rather just a simple cleanup, valvejob, install of all of the new hardware, but they will be 2.8l heads no matter what.
GURUMAN
The most inportant par in all these aspects is the 1-2 shift
if you guys dont want to be humiliated by a stage 2 car, calculations are the key...
I honestly don't care if other cars beat me. I'm not necessarily building this car around racing. I chose the hardware based on daily driving and road course racing aspects. I'm hoping, of course, that along with that it'll beat lesser cars, dyno decent and do a decent 1/4mi (and I'll film them, win or lose, good/bad), but those aren't driving priorities of the build like the others are.
Or if you're just talking about racing techniques and not hardware selection, then I agree, calculation and execution is the key. That's what separates from Evilempire and Marc from most of the other KO4 cars for example; they know what they're doing, can drive well (shift fast, incredible reaction time on the roll or launch), and know how to stack up the advantages that they can control on their side (tweak, race gas, drive alone, weight reduction (in Marc's case), no exhaust (again in Marc's case), etc.) So much is in execution, and it can make equal cars appear drastically different. That's definitely a big part of what made Evilempire and Marc S4 superstars.
wdbdy2000s4
I think the 2860s will be fine if he's revving to 8400. He shouldn't fall out of boost on the 1-2.
Yeah, I prob should've put that in my first post. I'm running 2860's with smaller housings. I choose these turbos so that they would spool decent on the 2.7. These should spool between 2554's and 2560's as is on the 2.7l. On a 3.0l, these will literally spool like KO4's.
Trigger Happy
Question, and it may be an ignorant one, but can you just put a 3.0l crank in without changing the bore? That would put displacement at 2.9 if I'm correct.
I've always heard that you can't because of the angle the new crank puts the rods in relation to the piston. They hit the skirts or something, and that's why the 3.0l specific pistons have shorter skirts. Someone correct me if I'm wrong.
Trigger Happy
IMHO your decision rests on how reliable a 3.0l is going to be for daily driving. I don't think the fuel mileage would differ that much from 2.7-3, and changing your driving style alittle should make up that difference.
To be honest, fuel consumption is quite a ways back in priority compared to reliability and daily drivability. It is still a factor (above, for example, peak horsepower), but not near as important as reliability. Though I bet the mpg difference could possibly be kinda drastic, cause I've heard of laggy big turbo S4's getting like 24 mpg, and I bet a 3.0 will never get above 20 combined no matter how I drive it.
Trigger Happy
Plus if you ever wanted to go all out you could build the heads much easier than swapping the crank out to go 3.0l.
Very true, and actually something I was definitely thinking about. Say I go 3.0l with the stock heads for a while and later I decide I really would rather be able to rev a little higher. I can pull the heads (maybe even without pulling the motor if I want to get crazy), and the only one-time hardware I'd really have to replace are $70 worth of headgaskets and the intake/exhaust mani gaskets. Though, on the flip-side, if I went 2.7 and built the heads, I don't think I'd ever have the inkling to go back and make it 3.0, so that part's not really a factor.
GaroBlu
my vote is also for built heads. If you are really concerned about gas mileage the 2.7 is the way to go. You will still have the power up top for when you want it. Besides, even with slower spool, you will be more than able to pass cars and get on the freeway quickly. I know having more power down low is good for a daily driver, but keeping stock displacement is the clear winner here.
As I said above, gas mileage is important, but not so important
And it doesn't make more power down in the lower range because it is more powerful when it's off boost, but it adds even more power down low because it'll shift my powerband to the left 400 RPM's (or whatever), so these turbos literally will spool like KO4's. Decisions decisions, it's a tough call!
sfored
It'd be interesting to hear from the GT guys who had the S4 as their daily drivers; don't get me wrong - once spooled ... it is a different experience but IMO not a "fun" daily driver
Like I said elsewhere, I can't think of one person (except for maybe Dom, who only cared about the drag strip) who went GT28rs or bigger who hasn't said that having them spool a little sooner would be nice. My turbos are nowhere near the size of Adam's (Evilevo) 2871's though.
imola
I'd rather have the 3.0 bore than high revving only.. I'm a fan of low end grunt.. Personally, I went with 3.0 (bored) and built 2.8 heads w/770s.. But thats as much as I can say since I'm still waiting on dp's and have yet to drive the thing and post on how much fun it is/isnt.
TweetsS4Estate
I still have yet to drive one lol takes forever to do it right sometimes! I'll tell you a 3.0L 2560 car would spool nice I've.
Both of you, keep us updated on it! Does it burn oil, how much increased low end, etc, and, as gay as it sounds, gas mileage lol.
GURUMAN
I had the chance to enjoy both 2.8L on 28rs and 3.0L on 28 rs
Peak hosepower was 576 WHP compared to 649 WHP
Was this on the same dyno, same exact hardware (other than the 3.0l stuff), and same amount of fine tuning on standalone? I don't remember.
GURUMAN
On a stock 6 speed tranny with 225/45R17 tires if you revv to 7500 to redline, when you shift second, you will get down to 4050 rpm
I didn't double check your math, but if that's true, I'm fine with that. With a 3.0l my turbos should already see some boost by 4000 RPM, if not very shortly thereafter. And that's just first to second, right? Like I said, I don't care as much about the dragstrip and racing from a dig, but care more about where I'll be driving 90% of the time (which isn't wrapping it out to 7500 from a stop through 1st and 2nd gear.)
buddysnack
What do 2.8 heads cost (if you are already going to be rebuilding your engine)?
Going from nothing to strapping built 2.8 heads on your car, around $3k if you're paying retail.
-$350-650 for the stock heads (not including shipping, they're 100lbs)
~$600 for standard valve job from a quality place
~$852 for valves
~$745 for ti springs/retainers
= ~$2550-2850 before shipping or tax
julex
if you don't want to screw around with boring a block, there is always an option of 3.0L crank and 81mm pistons (stock bore) or 81.5 (will fit with slight honing) made for 3.0l crank stroke. This lands you with 2.9L displacement and factory strong head, none of that 5mm of meat left on 3.0L block.
But.... is around 1.2k extra worth 200cc of displacement? most likely seeing that people spend that much on crap yielding far less HPs/TQ.
I don't mind boring the block, and I'll have to hone either way. So you're saying stock-bore aftermarket pistons, not using the actual stock pistons, right? And I cringe at thinking of spending $1200 for 6 pistons, so if that's what it's really going to cost me in the end for just the pistons, I probably won't do it. However, if I do buy new pistons, then I'll be saving $250 in rings that I'd be buying for the stock pistons, plus prob $60 of cleaning for the stock pistons, and I'd already be doing the $250 balance and $200 of other hone/machine work anyways, so it could make sense to go 3.0l over stock if I get convinced that they're reliable enough and if I can find them cheap enough.
So I know there were a few people on the forums (here and QW) that run, or had, a 3.0l. Guru, NogaroAvant is going to, Tweets4?, bryzf1 is in his Allroad, Imola will soon...but I know there's more. Can anyone remember off the top of their head?
