Originally Posted by
KNaudi
I'm running a mix of 2/3 Redline MT-90 and 1/3 Redline MTL in the tranny and 100% MT-90 in the rear diff. I hear (mostly from Scotty@advanced) that Motul is a better choice.
I just can't recommend Redline fluids with what I've seen inside the S4 gearboxes. Some people have had good results with Redline products, and some have not. However the few gear lube tests I've seen Redline gear oils do exhibit poor shear strength which could be the cause of the gear surface galling I've seen on some Redline lubricated boxes.
The factory stuff is pretty good as is the Motul gear 300. Both cost about the same, $15-$20 per liter.
FWIW, YMMV,BTDT, Caveat Emptor and all that other BS....
