Results 1 to 15 of 15
    Veteran Member Three Rings evola4's Avatar
    Sep 03 2007
    05' Audi A4 Ultrasport
    henderson, nv
    beep...beep...beep...brake...brake...brake...
    I was driving to work this morning and I was getting onto the freeway when my car gave me a warning beep three times and then the emergency brake light blinked three times. I can't tell you if I got a cel or not because my cel is always on as of right now until I get a cat delete file. I haven't had a chance to scan it for codes or anything yet because, like I said, I was on my way to work. I will scan it when I get home. Just wanted to know if anybody knows what this means. Thanks in advance. The car seemed to run fine the entire time I was driving into work though, so as of yet I have no clue what it could be.
    WTB K04 turbo ASAP
    http://etektuning.com
    Dec 11 2009
    Vancouver, BC
    Brake fluid level low I believe.
    Veteran Member Four Rings jonan's Avatar
    Nov 25 2006
    2X B7 RS4 - STG III B6 A4 (gone, but still in the family) - Mini R56 S - '15 Macan S - 997.1
    Austin, TX
    Quote Originally Posted by akira112 View Post
    yep
    Want my guns??? ΜΟΛΩΝ ΛΑΒΕ!!!
    B6 Mods:
    Fully Built Motor w/ GT2860RS and all supporting mods : My Build Thread
    RS4 Mods (sprint):
    RNS-e MKII : ECS SS : JHM Spacers : Deflapped IM : UM Tune : KW V3s : Tubi Rumore : Hotchkiss F&R SBs : 034 Diff Inserts : Phil Special Headlights w/ STI Lenses : 10 Layers : Spare 07BNS (#masterrace) : Apikol Diff & Trans Mount
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    delete
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Veteran Member Four Rings heateris's Avatar
    Aug 16 2004
    08 A4 2.0TQM6 ~ 08 Highlander Sport
    SE PA
    your pads might be low.
    Established Member Two Rings ultrasport69022's Avatar
    Aug 01 2008
    So Cal
    X3!
    Sep 10 2008
    TX
    fluid level low probably due to pads being worn
    internet sales at boardwalk VW in Richardson, TX/ cell 214-901-3449/ direct 214-453-6014
    05 A8 4.2 NBP everything but sport package
    02 A4 1.8 quattro tip
    08 aprilia scarabeo 100
    89 RX-7 vert
    85 RX-7 GSL-SE (i miss you)
    92 NSX (i really miss you)
    70 Chevelle (i dont miss you)
    Jun 23 2008
    Quote Originally Posted by evola4 View Post
    What ever happened with this? My emergency brake light started flashing tonight while driving, but it only flashes and beeps when I turn the steering wheel slightly right. Does NOT do it when the wheel is straight or turned to the left. No ABS light, nothing but the emergency brake light flashing.
    Established Member Two Rings cccp907's Avatar
    Jul 04 2010
    87 k1500 silverado, acura mdx, 87 Buick T-Type
    Bothell, Washington
    Quote Originally Posted by DownhillA4 View Post
    Also interested^^^^^^^^^^^^^^^
    Mine did that today twice:(
    Jun 08 2008
    Calgary AB Canada
    Check your brake fluid?
    2011 Audi A4 Avant // quattro // Garnet Red
    Stock. For now...
    1989 Porsche Carrera 4 // 5 Speed // Guards Red
    Veteran Member Four Rings Groove1797's Avatar
    Apr 08 2004
    Your mom on a unicycle
    Eating Cheese Curds
    It's related to your rear brakes and them being close to replacement or your brake fluid is low... end of story.
    4Runner, Rs5 and Alfa Guilia QV
    Jun 23 2008
    Quote Originally Posted by onceover View Post
    Been checked. That is not it. It's not a brake light in the electronic dash. It's the red light flashing "brake", the same light as when you pull the E-brake. Yet, mine flashes and beeps while i'm driving & only when i'm making right hand turns, no other time. I'm thinking it could be a speed sensor. Scanned the car, no codes. Very odd.
    Apr 08 2004
    Eating Cheese Curds
    Then it could possibly be your e-brake cable is stretched/caught on something. Happened to me when I first yanked the ebrake really hard on a hill.
    Jun 23 2008
    Quote Originally Posted by Groove1797 View Post
    Thanks for the replies Groove. I'm going to have to find my E-brake cable and see. In the end, how did you fix yours from the light flashing when you yanked on it to hard?
    Apr 08 2004
    Eating Cheese Curds
    Replaced the rear pads and cable. Pads were down to 2%
