Originally Posted by
mufflerman
To answer your question with useful information, all of the brands you mention use a straight through design core. Basically you can roll a golf ball through any of them. They deaden sound by absorbing it through perforation in the core of the muffler.
omgwtfbbq!
Either way the second half of my post stands with absorption type mufflers, they use packed material to create the holes for wave friction on top of using the actual holes themselves.
Well thank you both for the responses, I wasn't really sure if they were chambered or not.
Since straight through design has been established, i'll move on to my second question. I'm exploring my options for assembling my own exhaust "system". I figured before I even try dealing with fitments I might as well see if there is an innate design flaw or setback with the type of mufflers I plan on using. I found a muffler that is a dual inlet/outlet using 3inches in a "straight through design" although it's misleading because I found that it's not quite straight through. That particular muffler incorporates an x-pipe and I'm wondering if it will create so much turbulence and/or back pressure that it could negate the benefits of having a true dual 3inch exhaust.
