Results 1 to 40 of 43
Thread: 115k and...
    Established Member Two Rings chrisjackd's Avatar
    Oct 04 2010
    225 TT, B6 A4, B9 A4, 3.6 Passat
    Marietta GA
    115k and...
    What all should I be replacing around now? I know the timing belt is a for sure. I'm always scared when i'm driving its going to break D: I changed my coolant flange about 5k ago cause it was spewing everywhere, and my fuel filter needs to be changed, and I did spark plugs and coils at about 80k. Other than that what are some highly recommended things? BTW, when I was on here the other day I seen some post about after market wheels that "looked" just like actual Audi wheels. I believe it was some manufacture that manufactured wheels for Honda and Toyota. Any Suggestions? Thanks!
    Veteran Member Four Rings awdjunkies's Avatar
    Dec 18 2005
    sedan, avant, truck/suv
    nevada
    I always say that when I am doing an oil change why not change the plugs as well that way the car runs in tip top shape. Of course if you don't want to replace them each and every oil change, you can always do it every 2 oil changes. They are so cheap (And EASY to replace)that it's basically cheap insurance.
    If you are going to be doing your own timing belt, how about checking the Engine and tranny mounts while the car is apart. Another cheap part that some of us don't realize makes a big difference is your Snub Mount. Again while you are ing on it, might as well get her a few things that will eventually make a big difference in the driving pleasure.
    How are your brakes? fluid? Good Idea to check suspension bits too. Overall to make sure you don't have that "will she break down on me?" type of mentality each and every time you take her for a spin to the grocery store or better yet on a road trip.
    Established Member Two Rings ghostteck's Avatar
    Aug 07 2010
    04 E55 AMG, 08 M5, 16 c300, 2020 A6
    New York
    i just hit 114k and its making a weird whirring sound on cold start up when i turn the steering wheel or rev... kinda scaring me but when the car is warmed up its all good.. i wonder what that is...=p
    Veteran Member Four Rings Raiketsu's Avatar
    Jan 21 2010
    '10 Marin Bobcat Trail
    University of Georgia
    Quote Originally Posted by ghostteck View Post
    Probably just your belts warming up.
    Amulet Red 2003 Audi A4 1.8T
    Ecodes, Trunk Lip Spoiler, K&N Drop In Filter, LED Interior Lighting, DDM 55w 6000K Lows and H9 Retrofitted 2500K fogs, Depo LED Tails, painted brake calipers, and some VAG COM Mods
    Veteran Member Four Rings jonan's Avatar
    Nov 25 2006
    2X B7 RS4 - STG III B6 A4 (gone, but still in the family) - Mini R56 S - '15 Macan S - 997.1
    Austin, TX
    flush your power steering fluid...you're probably low on it as well, top it off for now but def flush it when you get the chance...
    Want my guns??? ΜΟΛΩΝ ΛΑΒΕ!!!
    B6 Mods:
    Fully Built Motor w/ GT2860RS and all supporting mods : My Build Thread
    RS4 Mods (sprint):
    RNS-e MKII : ECS SS : JHM Spacers : Deflapped IM : UM Tune : KW V3s : Tubi Rumore : Hotchkiss F&R SBs : 034 Diff Inserts : Phil Special Headlights w/ STI Lenses : 10 Layers : Spare 07BNS (#masterrace) : Apikol Diff & Trans Mount
    Aug 07 2010
    New York
    Quote Originally Posted by Raiketsu View Post
    Its a very scary sound, and the mount in front where the belt runs shakes alittle is it suppose to do that? sorry chrisjackd i like took the thread, im in the same boat as you so i gues all the questions help =)
    Sep 12 2008
    South Central PA
    timing belt
    EFR | 7163
    268/260 cams
    I.E. Intake Manifold / 70mm
    BoostManager+
    Meth Head
    Nov 25 2006
    Austin, TX
    are you talking about the tensioner for the serpentine belt? either way, i wouldn't drive around until you get that fixed...check up on your PS fluid though and make sure it's not low...
    B6 Mods:
    RS4 Mods (sprint):
    Aug 07 2010
    New York
    I think thats what it is the tensioner. it rattles on cold start. =/ its in the middle of the serpentine belt,The problem is this is my only car now that i sold the e55, I'm going to check the power steering fluid when i get the chance during lunch
    Oct 04 2010
    Marietta GA
    Quote Originally Posted by awdjunkies View Post
    Last time I changed the plugs I put the ones that are like 13 bucks a piece in them. (100k mile plugs)?
    Mine does too actually I have a video if that could help you guys figure it out. Its like a deep growl and rattle in the beginning. I hate cranking my car after it has sat for about 3 Hrs in front of people.
    Oct 04 2010
    Marietta GA
    And I recently did my rear brakes... Time for the front ones now.
    dispite whatever one else say's... if the whirring sound goes away when the car gets warm it your secondary air injection pump going bad.
    450whp 17psi @ 6400rpm on pump
    I am an a$$hole!
    SpecClutch.com | 034Efi.com | BoostFactory.net | QEDPower.com
    Oct 04 2010
    Marietta GA
    Quote Originally Posted by RecklessTuning View Post
    What does this do and where is it located? Mines been doing this the past 40k+ miles
    it helps your cat warm up quicker in cold weather for emission. It is typically located by the oil filter and it is a black odd cylinder. They cost around $165+
    I am an a$$hole!
    Aug 07 2010
    New York
    LOL IM A DUMBASS ....... i just opened up my powersteering fulid and saw that is was basicly empty i gotta get some ps fluid and i'll let you guys know, m1 atf is good right?
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    LOL!! You've been working on too many V-dubs! It's located just behind the radiator on the passengers side of the motor below and in front of the air box. You can trace the small intake tube connected to the front of the air box down to the SAI pump. That's where the SAI draws filtered air to send back to the combi valve.
    Dec 28 2006
    Western Maryland
    I am not a fan of using ATF for power steering fluid. Order online or go to the dealer and get the correct fluid.
    Feb 17 2004
    Liberty Hill, TX
    any particular reason? I've been running M1 synthetic ATF as power steering fluid for years now w/o issue
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by Matt Devo View Post
    None other than I just assume a fluid designed specifically for power steering use would be more appropriate than a fluid designed for an auto transmission. I really have no data to back up my assumptions. ATF apprently works fine as you have found out.
    true dat... I cant keep all the little querks straight lol
    I am an a$$hole!
    Aug 07 2010
    New York
    so im going to stop by autozone tonight and pick up M1-ATF since it seems to be working fine... i was trying to fine the thread where i saw it but it seems to have dissappeared
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Our cars require mineral based poswer steering fluid
    2019 SQ5 Prestige
    Nov 25 2006
    Austin, TX
    Quote Originally Posted by texasboy21 View Post
    QTF...yea, i mean unless you have plans to track it or something i would just go with OEM fluid...it's cheap and the power steering system is $$$ if you have to fix it...i know some people say M1 ATF has higher thermal resistance or something like that, but my car is just a daily driver...
    seriously consider driving around for 1k miles with an ounce of autorx in it though...my system was moaning even with the proper amount of fluid and it stopped moaning 300 miles into the cleaning...thank god...
    B6 Mods:
    RS4 Mods (sprint):
    Nov 25 2006
    Austin, TX
    oh and listen to old guy, him and diagnosticator basically have god status around here when it comes to advice...he's saved my ass multiple times...
    B6 Mods:
    RS4 Mods (sprint):
    Dec 18 2005
    nevada
    Quote Originally Posted by jonan View Post
    QFT!!!!
    Quoted For Truth!!!! [bowdown]
    Veteran Member Four Rings PDX04a4's Avatar
    Jun 22 2008
    2006 A4 Avant S-line
    SL,UT
    ya i would just stick to the OEM stuff, Pentosin 11s:
    i get mine at NAPA, its like 18 bucks a bottle.
    Thanks for the EFF shack. -Dirty Mike and the Boyz
    Feb 23 2004
    2004 A4 1.8T Ultrasport 6MQ
    Stow, OH
    You are WAY overdue for a timing belt replacement if this is your first one at 115k miles. Strongly suggest getting a complete timing belt replacement kit that covers the timing belt, tensioner, serpentine belt, water pump (with metal impellers), and a full coolant flush: http://www.ecstuning.com/Audi-B6_A4-...Timing/ES8147/
    I would inspect the valve cover gasket for any leaks as well as the front control arms (upper and lower). Brake fluid (DOT 4) must be flushed every 2 years regardless of miles. Depending on how old the car battery is (5 years or more), you might want to consider replacing it before the winter season starts. Replacing the power steering and transmission fluids with new OEM parts is a good thing too.
    Do a visual inspection of the vacuum and boost lines (if you're a turbo car). Make sure there's no splits or cracks. Other than that, stay on top of regular routine maintenance.
    USP CLUB MEMBER #34
    Aug 07 2010
    New York
    Does anyone in queens ny have power steering fluid the pentosin 11s or mobil 1 atf? I'm desparate right now, I check autozone gas stations stuarros. Napa noone has it.... if anyone does please let me know asap thanks ill pay you for it lol I'm below min. Like under the "N"
    Nov 25 2006
    Austin, TX
    you don't have a VW or audi stealer near you?
    B6 Mods:
    RS4 Mods (sprint):
    Aug 07 2010
    New York
    There is but there all closed as well =/
    Nov 25 2006
    Austin, TX
    damn that sucks, i have a whole liter of pentosin but i'm in stamford, ct...if i was closer i'd just top you off...
    B6 Mods:
    RS4 Mods (sprint):
    Aug 07 2010
    New York
    Aug 07 2010
    New York
    Thank you so much I really appricate it
    Aug 07 2010
    New York
    im going to stop by Napa tomorrow morning and hope they have it
    Aug 07 2010
    New York
    well added the pentosin 11s and everythings good but i will order backup's online from now on napa charged $30!!! when its freaking 18 + shipping online. i was like why so expensive, hes like take it or leave it lol i had no choice =/
    Veteran Member Four Rings A4OrlandoB6's Avatar
    Aug 03 2008
    Philadelphia, PA
    thats the convenience charge basically. lol you have an AMG. you should be used to dropping money on your car
    -Kyle
    2005 Audi A4 Avant USP / 1.8T / Brilliant Red
    2004 Audi A4 1.8T - big turbo and some stuff - gone
    2003 Audi A4 1.8TQM - gone
    Aug 07 2010
    New York
    Quote Originally Posted by A4OrlandoB6 View Post
    I am and i justsold the 55 so im just modding the audi now waiting to find the right E60 550i and im going to pull the trigger on that one =D
    May 21 2007
    Florida
    at 114k now. since 100k ive done: front brakes (purely upgrade, to b5s4 brakes), rear brakes, both front axles, power steering rack, all front control arms and tie rods, and general maintenance like oil changes and spark plugs.
    i had the timing belt along with waterpump, tensioner, roller, etc done at 70k and will be coming due again in 10-20k miles. if you havnt done it i would highly recommend it.
    2018 Navarro Blue Q5
    Nov 25 2006
    Austin, TX
    is it still moaning?
    B6 Mods:
    RS4 Mods (sprint):
    Aug 07 2010
    New York
    I'm going to fine out tomorrow morning because the car is all warm and good right now but so far nothing , my PS color was green before i even put in the extra
