Results 1 to 4 of 4
    Feb 06 2006
    '01 A4 1.8T, '01 Audi S4 Avant, '15 Dmax High Country, '01 Spec Miata #13
    Suffield, CT
    Question for those running Meth on BT/High Boost...
    What do you have your initial pump start setting at, and what is your max pump setting at?
    I am running 11psi start, 30psi max... while I am pushing 32psi through the motor... think I should max it out earlier, like 25psi?
    I am running AEM kit with dual nozzles... I think 575cc by the IC and 60cc at the tb
    Pics of the Meth setup I put in a week before H20i:
    2001 A4 1.8t | Under Construction
    2001 S4 Avant Hybrid K04, EPL Tuned.
    2014 Touareg TDI (Hers)
    2015 Chevy 2500HD Dmax High Country
    2001 Mazda Miata Spec'd Track Whore #13
    Feb 06 2006
    Suffield, CT
    and here I thought Audizine was where all the progressive guys were... no answers... wow.
    I guess I would have been better off posting on QuattroWorld, would have at least gotten some educated guesses...
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    I think starting is always good right around/just under half your max boost...
    I've noticed coming on too early will cause my car to hiccup....
    That said, do think your max should be lower then 30psi... I would try somewhere around 22psi for max and see how that goes... do a before and after log as well.
    also depends a lot on your tune...
    Feb 06 2006
    Suffield, CT
    Quote Originally Posted by NOTORIOUS VR View Post
    Thanks for the input... I will log/mess around on Friday.
    Side note: The tuning thread you have is key! I have been reading all sorts of stuff in the last few days in an effort to began tuning this ECU... I have a Uni Basefile... but I need to start tweaking it specifically. After looking at Maestro, I think I would rather just tune it myself in the end, that way I can also try to tweak the other Vag cars in the family!
