Results 1 to 16 of 16
Thread: timing belt
    Jul 20 2010
    Warren, NJ
    timing belt
    i just hit 82k havent changed the timing belt yet should i stop driving the car for now till i get it changed? i have a 2005 b6 a4
    Veteran Member Four Rings jonan's Avatar
    Nov 25 2006
    2X B7 RS4 - STG III B6 A4 (gone, but still in the family) - Mini R56 S - '15 Macan S - 997.1
    Austin, TX
    def get it done, you can do it yourself for around $300 in parts...i waited till i was 87k but i was driving on borrowed time and others weren't so lucky...
    Want my guns??? ΜΟΛΩΝ ΛΑΒΕ!!!
    B6 Mods:
    Fully Built Motor w/ GT2860RS and all supporting mods : My Build Thread
    RS4 Mods (sprint):
    RNS-e MKII : ECS SS : JHM Spacers : Deflapped IM : UM Tune : KW V3s : Tubi Rumore : Hotchkiss F&R SBs : 034 Diff Inserts : Phil Special Headlights w/ STI Lenses : 10 Layers : Spare 07BNS (#masterrace) : Apikol Diff & Trans Mount
    Established Member Two Rings VegasUSP's Avatar
    Apr 21 2010
    North Las Vegas
    I'm at 89 and i'm doing it this weekend. It definitely makes me nervous!
    Veteran Member Four Rings Kwarner's Avatar
    Sep 06 2009
    Bay Area
    i thought after a certain year it had the timing chain not the belt anymore
    Jun 08 2008
    Calgary AB Canada
    ^ WRONG
    2011 Audi A4 Avant // quattro // Garnet Red
    Stock. For now...
    1989 Porsche Carrera 4 // 5 Speed // Guards Red
    Nov 25 2006
    Austin, TX
    Quote Originally Posted by Kwarner View Post
    i hope that's a serious question and you're not just trying to troll....
    B6 Mods:
    RS4 Mods (sprint):
    Jul 20 2010
    Warren, NJ
    so should i stop driving this car its making me really nervous and does having revo stage one affect it at all
    Nov 25 2006
    Austin, TX
    OMG, i had 89k stock and didn't chip my car until after i did the TB and even that was pushing it...how long have you been driving around chipped? i'd do your TB like yesterday if that's the case...
    B6 Mods:
    RS4 Mods (sprint):
    Veteran Member Four Rings alpinestar180's Avatar
    Dec 07 2009
    1980 kz750ltd
    north new jersey/boston, ma
    the v8's are timing chain...maybe thats what you are thinking.
    2002 B6 A4 1.8TQM Sport suspension swap, RS4 rear Swaybar, joey mod, plasti-dipped front grills, and rear trunk trim.
    Diode Mod!!
    -Andrew
    Dec 07 2009
    1980 kz750ltd
    i made it to 95k miles before i did mine but for the last 20 k i dont think i hit over 4500rpms once haha. i was shitting myself i was so nervous. i did mine myself. its easy if you are mechanically inclined
    Diode Mod!!
    -Andrew
    Apr 08 2009
    Connecticut
    i'm right at 80K.. chipped with k04 software and redline it atleast once a day on the on-ramp to work. Cross Finger.
    stock
    Nov 25 2006
    Austin, TX
    Quote Originally Posted by dubgli View Post
    living on the edge award....
    B6 Mods:
    RS4 Mods (sprint):
    Veteran Member Four Rings akaEsCo01's Avatar
    Dec 08 2006
    Jersey
    Quote Originally Posted by B00stPlz View Post
    You don;t have to stop driving it but I would definitely be making plans to get 'er done. I had to change one on a car that had 65K but it was the waterpump, not the timing belt. The waterpump will more than likely go before the belt and you'll know when that happens and it won't let you drive your car, not far at least.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    You are correct. The latest version of the 2.0T uses a timing chain instead of a timing belt.
    Copied from an Edmunds review:
    Under the Hood
    The redesigned A4 is offered with two engines and a choice of front-wheel drive (FWD) or all-wheel drive (AWD), which Audi calls quattro. While the 2.0-liter turbocharged engine that Audi offered in 2008 was powerful and fuel-efficient, Audi has redesigned it for 2009. This version uses a timing chain instead of a timing belt and is both more powerful and more fuel-efficient. It produces 211 horsepower and 258 lb-ft of torque, compared with the 2008 version’s 200 ponies and 207 lb-ft of torque. FWD versions come with a continuously variable automatic transmission (CVT), while quattro models use a 6-speed manual transmission or a 6-speed automatic with Audi’s Tiptronic manual shift capability. Environmental Protection Agency fuel-economy ratings are 23/30 mpg (city/hwy) for the FWD sedan with the CVT, 22/30 for the quattro sedan with the manual, and 21/27 for the sedan or wagon with the automatic
    Veteran Member Four Rings A4OrlandoB6's Avatar
    Aug 03 2008
    Philadelphia, PA
    when should the timing belt be changed the second time?
    -Kyle
    2005 Audi A4 Avant USP / 1.8T / Brilliant Red
    2004 Audi A4 1.8T - big turbo and some stuff - gone
    2003 Audi A4 1.8TQM - gone
    Veteran Member Four Rings PRY4SNO's Avatar
    Jun 28 2007
    1990 Coupe quattro with all the parts
    Edmonton, AB
    To the OP, mine went kablooey @ 71k miles on the highway. Drive until you see a red oil light on the dash come up and at that point, no matter where you are, STOP. Well, if you're real close you might be able to nurse it home, as the warning will come up and go away, then become more persistent as failure becomes iminent.
    From the replies above you can see it's all dependent on an individual cars history so the interval can be a bit broad. Buy the TB kit from blauparts.com (cheapest and most complete) and when it arrives allocate the next weekend to DIY. After that you're looking at a replacement every 70k miles. I do mine at 100k km intervals just to be safe.
