Results 1 to 10 of 10
Thread: Firewall Hole
    Aug 31 2010
    California
    Firewall Hole
    I have a 02 A6....needed to wire something from the engine to the drivers seat and was looking for a spot in the firewall to send the wire through but couldn't find it. Where is the hole? Or where is a good place to drill one?
    Feb 07 2008
    The boonies, near Seattle
    Above the gas pedal to the upper right from the inside of the car. Should be a triangular grommet there.
    -dre
    Veteran Member Three Rings jmgraham78's Avatar
    Jan 19 2010
    2004 Acura TL, 2000 A6 2.7T MT, 2001 Allroad
    Dre - is that the same spot for running a boost line? Bout to begin my boost gauge in 2 weeks!
    2000 A6 2.7MT - currently gutted, a few parts left, PM me if you need anything.
    Aug 31 2010
    California
    Ok thanks, and how do I get to the wire once I've put it through the grommet, from under the hood.
    Feb 07 2008
    Quote Originally Posted by jmgraham78 View Post
    You can use that spot, yes. I drilled it out and run my 1/0 gauge through there. *shrug*
    Did I hear something about you using a passat column cover?
    Quote Originally Posted by coppertop4646 View Post
    Remove the underdash panel, there should be 5 8mm bolts. Once that is out you can look up and see it.
    -dre
    Aug 31 2010
    California
    Ok I get how to access the grommet from the inside but how do I access it from the outside, like when I open my hood, do I need to remove anything or will I be able to see the wire?
    Sep 09 2007
    2006 Honda AP2, 2016 C7 S6, 2017 4S R8
    Markham, ON
    remove the covers closest to the windshield! to make the job easier, you'd want some coat hangers and maybe some silicon spray lube =)
    Aug 31 2010
    California
    Ok thanks for the help
    Jan 19 2010
    DRE - you got PM!
    Feb 07 2008
    DRE - you got PM!
    Word.
    -dre
