Results 1 to 3 of 3
    Established Member Two Rings LuckyUSP's Avatar
    Jul 19 2008
    86 Toyota 4X4 PU
    Mill Creek, WA
    18X8.5 ET35 USP (Celebration wheel) replicas fit over B7 S4 brakes?
    As the title says, I'm doing complete B7 S4 brakes on the USP, the car currently has 19X8 ET35 Black RS4 reps, want to go back to the factory look for winter wheels and drop to 18s. Just want to make sure the celebration wheels will fit over the massive calipers, I have a whole finger I can stick behing with the brakes and the RS4 reps on the car. Just want to make sure before I order these wheels.
    *Samantha
    USP CLUB MEMBER #500
    Veteran Member Four Rings belinko's Avatar
    May 09 2005
    Audi 1.8T QM
    Encinitas, CA
    I don't see why not as all factor S4's came with 18's, just compare your offsets before and after.
    http://www.rimsntires.com/specs.jsp
    1.8L, JE pistions, IE rods, APR stg3+, GT28 Turbo, Setrab, ER comp. FMIC, APR HFC, Milltek Cat-back, APR 91, 93, 100 - CM FX 300, CM 240 LWFL, JHM 4:1, AMS SS, RS4 Motor Mounts - 355mm Alcon 4 pot, 300mm Alcon S4 - Stasis/Ohlins MS, Hotchkis Front and Rear, Stern adj. CA Front, 034 adj. CA Rear - 18x8.5" Work CR Kai wheels, NT-01 & Dunlop Z1 star spec - RS4 Front bumper and grill, Tow Strap, RS4 E-codes - SPA Technique Dual Digital gauges Oil & Water temp, Oil & Boost pressure, RS4 Door Handles
    Veteran Member Three Rings bl0wn3ur0's Avatar
    Jul 22 2008
    NY/PA
    well the B6 S4 wheel is 18x8 ET44, i really doubt that they changed the offsets for the B7 wheels(since its the same chasis anyway) so you should be fine.
