I'm pretty much looking for a decent set of 18" but I don't understand how the whole offset/hub bore ordeal works. Will all 33et offset wheels clear the fronts no matter what the hub bore size is? Does having a lower et always mean that the wheels will be sticking out more than a higher et would? I'm trying to avoid the same mistake I once did which was to buy a set of wheels not realizing they wouldn't clear the fronts. I'm trying to avoid using spacers so if anyone could help me understand how wheel fitments work and what et and or hub bore I need to use to clear the fronts I would really appretiate it. I know there was some wheel calculator that showed you whether or not a wheel would fit the car but I forgot the link.
Thanks for the help as usual!
