Results 1 to 14 of 14
    Established Member Two Rings mikebo212's Avatar
    Sep 18 2010
    Burlington NJ
    Ignition problems?!
    I bought the car a couple weeks ago and since I've noticed it takes a little when turning it on, cold start and sometimes even after it's been warmed up. I've been reading but not sure if the coil pack could be bad, fuel pump, etc suggestions would help a lot
    Established Member Two Rings LXAAUDI's Avatar
    Nov 13 2009
    Toro Lawn Mower
    Ashburn, VA
    Is it cranking when you turn the key or just doing nothing?
    2008 Audi A4 3.2Q S-Line Titanium 6MT
    Fly's V4 Headlights, K&N Drop in Air Filter, Eibach Pro-Kit Springs, Koni Sport Shocks, De-Badge,
    RS4 Grille, AWE S4 Quad Exhaust, RS4 Rear Sway Bar
    Sep 18 2010
    Burlington NJ
    it cranks but it takes like a couple seconds to start I dont think it's normal
    Veteran Member Three Rings makav3li's Avatar
    May 06 2010
    Ellsworth AFB, SD
    call the dealer and see if the coil pack recall has been done. Otherwise, change ur plugs or see how long its been since thats been done when u ask about the packs.
    Selling Nogoro blue Alcantara door panels. Will fit b6/b7 a4/s4/rs4. In great condition, originally wanted $600 shipped but dropped price to $500 shipped. Check my classifieds for pictures. I want these gone, will include extra door clips if requested. PM me if you want pictures of them installed or anything else I want these gone so make me an offer and we'll talk.
    Sep 18 2010
    Burlington NJ
    Sep 18 2010
    Burlington NJ
    I no longer have warranty so i don't know if the recall will apply and i recently changed the plugs as well but thanks I'll probably just change the coil pack
    May 06 2010
    Ellsworth AFB, SD
    even if the warranty is out, they will still change the packs, it is a recall so it has to be done free of charge. No harm in calling them and giving them ur vin number to see if theyve been done.
    Sep 18 2010
    Burlington NJ
    oh ok thanks for clearing that up I really wasn't sure If I needed the warranty or not, ill deff be giving them a call
    Veteran Member Four Rings shiro1745's Avatar
    Jul 26 2009
    South Jersey
    I still have the same problem after they've changed the coil pack. I'll be happy to find the problem. I was never to worried about this. But I'll try changing the plugs. Any other things could be bad except the coil pack and plugs?
    Sep 18 2010
    Burlington NJ
    I called Audi and they said my pack was changed in Jan of 09 so the next step is to bring it in and let them diagnose the prob. At this point i don't know what else it could be
    Veteran Member Three Rings grizzles's Avatar
    B8 S4 Avant
    Switzerland
    Do a search for cold start problems. This is a known issue with B7s...seems to be mainly 06's although other have had issues. Myself and others have had the dealership try and fix the problem with no luck. The only thing that seems to help is to put the key in the on position for a second or two before cranking. You will hear the fuel pump prime when you do this (although it starts when you open the door, must not be long enough). I have never had the car fail to start, just an extended crank so it's more of an annoyance than a problem for me.
    Jul 26 2009
    South Jersey
    Quote Originally Posted by mikebo212 View Post
    I've had the car in at Audi dealer at least 5 times for this problem, never got to the bottom of it. They said it was nothing wrong and they could not duplicate the problem while the car was there. I also left car at the dealer 3 times over night just to make sure they get it in the morning(that was in the winter). I always got the same useless answer: "nothing wrong with the car". So I kind of stoped thinking about it. I would like to get it fixed though. I'll try to spend some time reading the "Cold start problem" thread, maybe there's some useful information there
    Sep 18 2010
    Burlington NJ
    Ill prolly try the whole waiting 3 seconds and see if it worls. Buy they'll probably end up telling me the same thing, I'll just have to wait and see I'll keep you guys updated
    Veteran Member Four Rings airbornerifleman's Avatar
    May 20 2008
    2013 Passat TDI
    Toronto Ontario, Canada
    Quote Originally Posted by grizzles View Post
    ^this^
    2006 Audi 2.0T quattro Tiptronic
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
