Results 1 to 34 of 34
Thread: Vented hoods
    Nov 14 2006
    600hp glorified Beetle, Tacoma, motorcycles
    Renton, WA
    Vented hoods
    I really like the look of vented hoods and there are several out there for our cars from different manufacturers. Does anyone know anything about the different options and which of the hoods have the best vent placement?
    I'm assuming the lowest pressure spot on the hood is somewhere near the center? Or is it more towards the front or maybe back the back of the hood near the windshield?
    Would two louvered vents or maybe NACA ducts on either side of the hood be the best option? Or would a big opening in the middle of the hood (like on an Evo) be the best choice?
    -Darrick
    No more Audis, but I can't seem to leave this place.
    Oct 06 2004
    Minnesota
    I run a vorsteiner hood with the center louver vent. I do believe it is effective. At stoplights I can see heat pouring out the louver.
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Mar 02 2008
    Baltimore ,md
    Heres what I have. Just a stock hood with a NACA vent. This is about as far back as you can put it. Sits rite above air filter.
    Veteran Member Four Rings TighTT's Avatar
    Feb 21 2006
    Widebody'd avant with AZR 3.0 TTE 950+
    NJ/NYC
    Like Rob, I too have a vorsteiner hood on my A4. I personally would skip the whole vent idea. My bay is constantly wet/dirty.
    50% Blood
    50% Sweat
    50% Forced Induction
    Thats 150% motherf*cker.
    Veteran Member Four Rings wdbdy2000s4's Avatar
    Oct 08 2008
    1998 pathfinder, 2000 s4
    MA
    does the vorsteiner have a rain tray?
    Frimmel: i only speak when i have something negative to say.
    Grah4m: i lost to a giraffe. be careful out there.
    ThirdStrike:leave your feelings at the keyboard
    Feb 21 2006
    NJ/NYC
    Quote Originally Posted by wdbdy2000s4 View Post
    Nope...just vents. Dont get me wrong...IMO its the absolute highest quality hood available for our cars...which is why I bought it. Also my A4 generates some serious heat...so its nice to have. The downside is when it rains...my coils get soaked, etc, etc.
    50% Blood
    50% Sweat
    Veteran Member Three Rings omgwtfbbq!'s Avatar
    Jul 08 2009
    Daytona Beach, Fl
    Low pressure area on the hood?
    wat?
    01 Sedan /// Brilliant Black ///F4H Frankenturbos w/ tubular manifolds /// J-Fonz stage 3- /// Borla 3" /// Darintake
    I hate: FMICs, flat colors, A-pillar gauge pods, vented hoods, drilled brake rotors, SSAC products, Rotas, you
    Active Member Four Rings
    Sep 11 2007
    Tampa, FL
    Isnt there a hood out there that has vents on both sides.
    Nov 14 2006
    Renton, WA
    Quote Originally Posted by omgwtfbbq! View Post
    wat?
    Aerodynamics. As air goes over the hood of the car it causes a low pressure zone. If a vent is located right below that spot on the hood, it will pull hot air out of the engine bay as you drive.
    -Darrick
    Jul 08 2009
    Daytona Beach, Fl
    You will have an area of lower pressure immediately aft of the headlights, but everything else is exposed almost directly to the air flow, and will be under quite a bit of high pressure. The original engineers did design these cars with heat flow in mind, punching holes in the hood would tend to cause turbulence, effectively heat-soaking the air under the hood, decreasing cooling effects and creating possible heat concentrations. The best method of heat dissipation would be routing more air through the radiators, through the engine bay, and down the underside of the chassis, like the original design. You could do that a number of ways, the easiest of which would be flat-bottoming the car.
    And if you try to tell me a forward facing naca duct is going to suck heat out of the engine bay you are high.
    Sep 11 2009
    NE
    Quote Originally Posted by Capt. Obvious View Post
    And you can start saying that you have a heated windshield as well!
    Sep 27 2007
    00 S4 6sp, 06 Mazda3 HB Auto
    Columbia, SC
    I think the vent is the actual cause of the low pressure and not the hood. You might have one right behind the headlights and right in front of the windshield by the hood since it has a lip.
    00 B5 S4 - K04, Stern Soft MM, Stern Snub, DTS, Neuspeed Rear Sway, Oinkies, GIAC stg 2 XR, Vogtland GT, SSAC copy. Soo... Stg 2.31456?
    06 Mazda3 - Wife's car and autox car
    96 Eclipse GSX - Gone
    03 Acura CL Type S - Gone
    96 Soarer GT - Gone
    93 RX7 R1 - Gone and missing her
    Nov 14 2006
    Renton, WA
    What options are there for vented hoods?
    I know of the Seibon and the Vorsteiner, any others?
    -Darrick
    Veteran Member Four Rings veggiemonster's Avatar
    Oct 20 2008
    fuck off
    why don't you space the hood like honda people's so you have an "engine bay" vent the size of the bay. the added turbulence would suck out heat, and you wont have to worry about water.
    Sep 27 2007
    Columbia, SC
    These kind of vents worked very well on the RX-7 (and that is one HOT engine). Kept water out pretty good as well. I think this kind of vent (not same size or number, just the style) would work ok. I think the new Aston Martin has vents on the hood as well.
    96 Soarer GT - Gone
    Nov 14 2006
    Renton, WA
    Quote Originally Posted by sdoherty_tjm View Post
    Two reasons.
    1) I don't think that looks good.
    2) I don't think it will work very well with our hoods since the hood includes the front grill and wraps over the front of the car.
    I'm not worried about water in the engine bay, there's plenty of ways to keep it out while still allowing venting.
    I really like the B7 RS4 Vorsteiner hood:
    -Darrick
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Every Seibon hood I have seen is total crap. I would never waste my money on their cheap Chinese carbon products.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Oct 20 2008
    fuck off
    OP, just throwing it out there. thought about it for myself as i'm sick of spending moniez on the s4, and i don't have a EFK with my FMIC. i'll test it myself sometime in the future.
    Nov 14 2006
    Renton, WA
    I feel ya there with spending more money on the car, I'm too busy replacing every sensor on the engine since I seem to need a new one every other week...
    My hood is kinda messed up (been repainted half a million times), so I'm thinking about just sacrificing it in the name of Idontgiveafuckanymore and cutting vents into it and fabbing up a removable rain tray for each vent. If it looks like shit, I'll buy a carbon hood.
    -Darrick
    Oct 20 2008
    fuck off
    i would have no problem doing that with mine either. especially if yours comes out looking even half decent.
    mine has more rock chips all the way through the 3 coats of silver and 2 primer coats (at least). lol they are big enough i can tell its been repainted a couple times. and i wouldn't mind a "reason" to get a carbon hood...i just can't do the "but i want it" shit anymore with this thing
    Veteran Member Three Rings Avant Fetish's Avatar
    Nov 13 2008
    Mk7 GTI / 8P A3
    So Cal
    Is there a reason the vents are placed so far up front? Doesn't the majority of the heat gather towards the firewall where the turbos are?
    Has there ever been any tests where under hood temps were measured? Seems like the vents are more cosmetic??
    Cup | Corrado | Cervelo S2 | Banshee Spitfire | Evil Following
    Nov 14 2006
    Renton, WA
    Quote Originally Posted by Avant Fetish View Post
    That's basically what I was trying to ask with this thread. Cosmetically, I like vented hoods and I want one. But if I'm going to get a vented hood, I might as well get one that is functional. If none of them are truly functional, I'll just get the one I like best.
    -Darrick
    Nov 13 2008
    Mk7 GTI / 8P A3
    So Cal
    I remember Mugen actually wind tunnel test their front bumper and hoods.
    You might as well just pick the hood you think looks best. IMO...the vents on the Audi hoods are nothing more than cosmetics.
    If you are going to cut your hood...maybe check where the E46 M3 vents are placed...
    Its actually something I've always wanted to do to my Corrado...but never had the cojones to cut up a good hood!
    Jul 08 2009
    Daytona Beach, Fl
    Just get the one you like best.
    Senior Member Three Rings hellrot98m3's Avatar
    Dec 21 2009
    i sort of like this one because its simple. i have the vented vorsteiner hood on my m3 and the quality is of the best that ive seen.
    http://cgi.ebay.com/ebaymotors/SEIBO...ht_3913wt_1165
    Senior Member Three Rings Tormented's Avatar
    Sep 12 2010
    2007 Mazda 6
    Texas
    Quote Originally Posted by hellrot98m3 View Post
    You do realize that hood is not vented right? It's simply a CF hood, the OP asked about vented hoods.
    Nov 14 2006
    Renton, WA
    A more technical discussion on the topic:
    http://www.honda-tech.com/showthread.php?t=2766239
    I'm going to be putting my vents just after the radiator. I'll try to do some before/after logs too.
    -Darrick
    Veteran Member Two Rings
    Mar 21 2004
    Philadelphia
    remember you also need to work around the framework of the hood as well or you risk making a floppy hood as flat sheet metal is very pliable.
    Veteran Member Four Rings NishadJoshi's Avatar
    Apr 22 2010
    Playa del Rey, Ca
    ^I REALLY like that hood too, super clean. I wish they made one with a similar style (dual vents) for the B5.
    derp.
    Veteran Member Three Rings SummitS4's Avatar
    Sep 19 2006
    2001 audi s4
    Los Gatos
    Has no one really mentioned the fiber images hood? Friend of mine said it kept the engine 150* cooler on the track.
    2001 nogaro s4 2.8 tial 770's........... 1972 Audi 100ls Bagged
    530 awhp 540 awtq on 91
    Sprint Auto Works / Becausebags
    Rotiform/Airlift
    Nov 14 2006
    Renton, WA
    No way it kept it 150 degrees cooler, did you mean 15?
    -Darrick
    Nov 13 2008
    Mk7 GTI / 8P A3
    So Cal
    What about placing the vents towards the rear of the hood like the E46 M3...or even vertical vents like the mk2 golf?
    The majority of the heat comes from the area of the firewall where the turbos are...no?
    or does the heat from that area gets pulled out from the bottom of the car?
    Nov 14 2006
    Renton, WA
    Having the vents towards the front of the hood allows the most air to be pulled out best because that's where the pressure is lowest. As you move closer to the windshield the air pressure gets higher as the air "stacks" against the windshield.
    Also, having the vent more towards the front will pull the hot air that has just traveled through the radiator up and out of the engine bay.
    -Darrick
    Nov 13 2008
    Mk7 GTI / 8P A3
    So Cal
    When I pop the hood after city driving...the back of the motor seems to be generating most of the heat. Wouldn't it make more sense to dissipate the heat from that area instead of the radiator that already has air hitting it? At least at lower speeds...the heat will have somewhere to go.
    When the car is moving, the engine bay is under vacuum anyways. Driving home from my girlfriends place is mostly highway. When I get home, pop the hood...the intake and engine covers are cool to the touch. The front of the bay may have the lowest pressure...but it seems to generate the least amount of heat also.
