Hi guys.
I'm trying to install a BOSCH 044 pump on my RS4, and i have a few issues.
1) the fuel pump does not fit the V8 basket i've bought. If inserted from below, the notch on the pump is blocked inside the basket...and the pump doesn't slide all the way up. If inserted from above, there's a little filter protruding inside the basket which blocks the pump.
installed from below
installed from above
2) the second problem is with the fuel lines. The RS4 fuel system seems to be different from the S4 one. On the RS4 the fuel pump output separates in two different pipes...one goes to the fuel pump cap and then to the injectors. But what about the other one? Do i have to keep it or should i tap it off?
I'm thinking about removing the small filter on top of the basket with a dremel to insert the fuel pump from the top.
This way i'd get it installed like the 034Motorsport one. BUT doing so the fuel pump pickup will sit a couple cm higher than the OEM pump....could this lead to pickup problems when low on fuel? (see pic below for reference)
P.S.
Should i use copper washers here even though the fitting is aluminium?
P.S.2
Do i really have to remove the check valve on K04 hybrids and EV14 750cc injectors? I'd prefer to leave it on, but i don't want it to limit the power output etc....
Thank you!
