Results 1 to 25 of 25
    Veteran Member Three Rings SN95Audi87's Avatar
    Apr 26 2010
    96 Mustang GT/2001 Audi 1.8T
    North Jersey
    Need Urgent *HELP* - Dash Cluster problem!!
    Ok. After this huge rainstorm... I go to turn on my car and I see no power to my dash cluster. So I'm like "WTF" in my head. Me being a noob, and new B5 owner for a few months, this situation scared the crap out of me. I see all the self-check diagnostics come on when I start the car. But the needles dont move or anything. At Night its even worst. I have no LED interior light for the overhead near the sunroof. Everything else works just fine. I am basically driving blind, and wondering if anyone can help.
    I'm guessing its blown fuse but I had to go straight to work. Couldn't tamper with it at all.
    Apr 26 2010
    North Jersey
    Anyone!
    When I started up the car, the rpm doesn't read and nothing else turns on. No power to reiterate, only thing is i see the regular self-diagnostic checks and my blinkers work. Everything esle in the car interior related works. Just the dash cluster is completely off.
    Established Member Two Rings CycloSteve's Avatar
    Apr 23 2008
    My Own Private Idaho
    First check the fuse box for any blown ones. If none blown, then try pulling the cluster and checking that each of the plugs are properly seated into the cluster itself...beyond that start combing through the service manual (Bentley).
    2006 A4 2.0T Quattro Avant Manual - Let the mods begin
    2006 A4 2.0T Quattro Sedan Manual - Son's 2nd A4, well on the path to Stage 2+
    1998 A4 2.8 Quattro Avant Manual - PES G2, Milltek Exhaust, DTM 18x8's, Hotchkiss Swaybars, StopTech Stage II, PSS9 Coilovers, APR Snub, Podi, JHM SSK, Unorthodox LWFW, South Bend Stage 3
    Non-Audi Vehicles include multiple Landcruisers, Cayenne, BMW 335, trials and dirt bikes, M3 Euro-delivered from factory - SOLD and missed
    Apr 26 2010
    North Jersey
    The fuse box is located on the driver side dash board right?
    Senior Member Three Rings ADNpro's Avatar
    Sep 11 2009
    2013 WRX Hatch | 2010 Mazda 3
    Westfield, NY
    Yes, on the side where most are located.
    Apr 26 2010
    North Jersey
    I checked #15 - 10a fuse, and it looks in perfect condition. Now pulling it made my diagnostics lights on the dash come on, but still no illumination for the dash or needles moving. And now my radio is in safe mode. Just gets suckier lol. Someone help...
    Established Member Two Rings alsabti3's Avatar
    Aug 19 2010
    ann arbor - MI
    was your car struck by thunder? did you survive?
    Apr 26 2010
    North Jersey
    Lol. No I wasn't struck by thunder. And the car was parked under the tree when it stopped raining. I really hope the cluster isn't fried. *shaking my head*
    Jun 30 2008
    Erie, Pennsylvania
    How about the radio or reverse lights? Do those work? For the radio, does it turn on and off with the key like it should?
    I'm thinking you possible lost power on part of the 15 circuit due to a faulty ignition switch.
    Apr 26 2010
    North Jersey
    Yeah well, before I pulled the fuse... I drove the car to work with no dash light/or needles. Reverse lights and everything comes on. If it was a faulty ignition switch, shouldn't the car not start?
    Mar 23 2008
    Queens Ny
    im having this exact same problem.. cluster wont illuminate, none of the needles will move. everything else works headlights,signals,and side markers. my self diag check wont work nor will the time and mileage turns on. only lights that come on are epc,airbag,abs,brake,and the battery sign.
    Jun 30 2008
    Erie, Pennsylvania
    No, there are several outputs from the ignition switch other than the starter signal output.
    So you are absolutely sure the reverse lights work and if the radio is left on, it shuts off with the key and comes back on with the key automatically?
    Does the odometer work? It should show you the miles as soon as the driver's door is open (no key required).
    Also check fuses 14, 38, and 6.
    How are you checking the fuses? With a test light? Voltmeter? Ohmmeter?
    It really seems like either the cluster is not getting power from the ignition switch, or the cluster is dead. Have you tried jiggling the key, or turning slighty backward or forward?
    Apr 26 2010
    North Jersey
    Yep! This is exactly what I am going through! The ignition switch sounds like a plausible cause but I'm not to sure.
    I'm checking fuses by just pulling them and seeing if they are burnt. I'm not using any electrical equipment at all.
    The odometer doesn't work, LCD screen off, time/date off. No needles move at all.
    Jun 30 2008
    Erie, Pennsylvania
    It is generally advisable to use a test light or volt meter when checking fuses. A fuse can look good visually but still be blown (not usually, but it happens). Also it lets you know that the circuit is up. If the fuse is good, but the fuse isn't even getting power with the key on, you've got other problems.
    Sadly, the power source in question (from the ignition switch) doesn't even run through a fuse after the switch. So it isn't very easy to do a quick check. Reverse lights run off the same circuit, so that gives us some idea, but there could still be a wiring fault. Would have to pull the cluster to see on that one.
    Apr 26 2010
    North Jersey
    well I check those fuses by a visual and nothing seems wrong. I will dig deeper into it later with a voltmeter. Just to let you know my low beam light doesn't come either if that can give you any ideas. When I push the stalk forward doesn't stay one.
    Nov 30 2008
    06 Wrx
    Olympia, WA
    Quote Originally Posted by SN95Audi87 View Post
    Definetly take Walky_talky's advice on this one. He's helped me and many other people through similar situations. Good thing for you, The ignition switch isn't expensive at all lol
    Jun 30 2008
    Erie, Pennsylvania
    my low beam light doesn't come either...When I push the stalk forward doesn't stay one.
    Please explain what the means...
    The low beam indicator on the cluster, or the actual low beam headlamps do not operate? What about high beams? What about wipers?
    Mar 23 2008
    Queens Ny
    hit the dashboard a couple times and power and everything started to work again lol.
    Apr 26 2010
    North Jersey
    The low beam indicator on the cluster does not show. When you click the stalk forward to make the high beams stay on permenant doesn't work. It only works when I pull the stalk back like if I am going to flash someone. Other than that the dashboard cluster doesn't work at all, and all my indicator warning lights are on. Sorry, the epc light is on as well.
    I've some heavy research, and read a lot of threads.
    It could be ignition switch, some type of relay where I dont know where the relay box is, or my cluster is just fried.
    Jun 30 2008
    Erie, Pennsylvania
    And what about wipers? You didn't answer that one...
    Apr 26 2010
    North Jersey
    Wipers work perfectly. I'm sorry that I haven't answered your questions fully. Just nervous about the situation, its just such a awkward/weird problem that I almost couldn't sleep good! Ah!
    No Vent illumination either. Everything else works list below
    Interior lights - ok
    Vent lights - dead
    Dash Cluster - dead
    Headlights - ok
    Foglights- ok
    Tail lights - ok
    Radio - ok
    Driveablility - ok
    Warning lights - (on) except of Lowbeam light
    Reverse Lights - ok
    Cigarette light - ok and power works
    Overhead mirror lights - ok
    Trunk light - ok
    Rear Fog light - ok
    Alarm parameter lights - ok
    Apr 26 2010
    North Jersey
    Where is the relay carrier located on these cars?
    Jun 30 2008
    Erie, Pennsylvania
    Aha. So the actual low beam and high beam headlamps are working, it is just their indicators on the cluster that aren't working.
    Most of the relays in the B5 are in the relay carriers behind the driver's "knee bolster" (aka "kick panel" or "lower dash panel"). You have to remove a couple 7mm hex head bolts to get it off. The top ones are hidden behind the oblong plastic "plugs" in the dash. You gently pry those off to access the small bolts.
    Anyway, I don't know what you would exactly check there. The cluster is not powered through any relays. It is powered directly from the ignition switch. I think more benefit would be from pulling the cluster and checking for power and ground supply at it's connector(s). Specifically checking for 15 circuit power supply (Hot in ON and START) to pin 1, the black wire, in the 32 pin connector.
    Apr 26 2010
    North Jersey
    Thank you! My friend is coming over tomorrow, or wednesday. We are going to pull the cluster and test for power. We will let know what's up. Also do you have any idea why my warning lights are on all at the same time? Just curious. Looks like a light show. It happened when I pulled the instrument cluster fuse, then put it back in.
    Apr 26 2010
    North Jersey
    This thread can be finally closed. The car is fixed and I am happy.
    Story: The cluster was taken out at one point and wasn't correctly put back in. I am novice Audi owner so I wouldn't have known. Anyways the connectors have this clip in the back that you have to press firmly. My friend pulled the cluster out tested the connectors everything was good. So we put the cluster in thinking we need to replace the ignition switch and PRESTO. Everything turns on beautifully. At this point I am very happy/ecstatic. Also while we have the car in pieces. We took the front bumper off because I ordered new clips for the bumper to slide on too. So everything worked out great and I give all the credit to God and my best friend Alex and his brother for helping. Take care everyone!
