Results 1 to 12 of 12
    Jan 20 2010
    Northern NJ
    Fender pulling/rolling questions.
    My rear wheels are 18x9.5 with an offset of 33mm and right now everything runs perfectly because I'm on sport suspension and the fender isn't low enough. The problem is I'm starting to hate the gap and will be buying coils over the winter. I need more room in the rear, maybe 1/4 to 1/2 an inch? More towards the 1/4 mark but anyway, is this room available through fender pulling or what? I want to eventually tuck half my rear tire. If that helps.
    Thanks in advance.
    Gary
    Senior Member Two Rings matthewb2795's Avatar
    Mar 13 2010
    2005 Buell XB12s
    Michigan
    What size tires?
    -2007 Brilliant Black Audi A4 Titanium S-line, 6-Speed-
    STaSIS SS Coilovers / RS4 Rear Sway Bar / Podi Electric Boost Gauge / APR Tune / 034 Turbo Inlet Pipe /18" RS4 Reps (previous owner's mistake, looking to fix this soon)/ H&R TRAK+ Spacers 15f, 20r - Final ET 27f, 22r
    Seeking OEM B7, or B8 Ti wheels, PM me!
    Jan 20 2010
    Northern NJ
    245/25/18 off the top of my head. will re-check tommorrow
    Veteran Member Four Rings eskimopunk's Avatar
    Mar 26 2008
    63 Ford Falcon Futura Convertible
    Las Vegas
    find a friend with a fender roller. Roll them bitches. Although I think the rears are pretty hard to do with the location of the calipers? I only rolled my fronts. You won't be low enough to make pulling worthwhile.
    25? I think you mean 35.
    flickr
    "ALL I REMEMBER IS ARGURFIN WITH DRCURITY AND THEM KICKING me out of neptunes i ve had like 6 LIT's biches is crazy my backj fucking hurts" - El_Chapusca
    SBSC Designer
    For awesomeness. Thanks Pat.
    Jan 20 2010
    Northern NJ
    i probably do, i forgot which number measures the sidewall height but they are "low profile"
    Veteran Member Four Rings CleanA4's Avatar
    Jun 23 2009
    B5 s4, 06 gsxr, lawnmower
    Chicago
    stretch tires!!!!
    2001.5 S4 -GIAC stage 1, SSAC TWIN ll, OZ Superleggera
    2006 gsxr 600
    2004 USP- sold
    Lawnmower
    NEED A FENDER ROLLER? OR FENDERS ROLLED?-PM ME
    -Admir
    Jan 20 2010
    Northern NJ
    well i mean the problem is the actual rim is flush with the fender, the tires already have some stretch to them believe it or not.
    Veteran Member Four Rings vbrad26's Avatar
    Oct 17 2009
    MK7 VW GTI
    St. Pete, FL
    you can always run a little bit of negative camber...that would prevent rubbing...
    Jan 20 2010
    Northern NJ
    Afraid to go through tires every four months though.
    Jan 20 2010
    Northern NJ
    Also tire sizes=
    Front- 225/40/18 et 39
    Rear- 255/35/18 et33
    Oct 17 2009
    MK7 VW GTI
    St. Pete, FL
    im running -2 all the way around and am going on a year with no rotations or anything...they are actually doing pretty good...
    Veteran Member Four Rings Dangler's Avatar
    increase your camber, max it out. as the suspension compresses, the camber angle increases, and you may just miss the fenders, if not, then pull them a little, and stretch tires are your friend too. i ran 19 x 9.5" unknown et, but they sat flush. i only rubbed with a fully loaded car. Me driving solo, i didn't have any issues, and i have no tire gap.
    PRIME MOTORING
    F.T.W.L.T.B.D.W.I.C.T.W
