for about 30min i was searching the forum and no one else that i saw has/had the problem i have.
starting off from a stop in 1st it is fine no lag but when i let off the throttle and push the clutch in to shift (doesn't matter what gear just as long as you are at speed) it revs up about 300rpm from where i let off say 3,500rpm it revs to 4,000rpm and then idles down VERY slowly.
shifting between lower to higher let the clutch out press the throttle accordingly and there is a lag before it notices the throtle is pressed. like shifting into another gear letting out the clutch and not pressing the gas like that kind of feel.
now it does not rev up when i am decelerating it just holds rpm and then slowly idles down. if i were to rev match, it is a worse lag on the throttle then when accelerating.
it started doing this begining of sept. i took it to autobahn performance and it did it for their tech so he hooked the vagcom up to it and NO CODES and he said everything was working in the normal parameters.
if i had and knew how to use a vagcom that would kick ass... but i don't.. shit.
i did try that key on press the trottle wide open for 3sec. turn key off don't remove key let off the throttle then after 2min remove key insert key and start blah blah blah but yea nothing.
this is driving me nuts and i DO NOT want to take it to the dealer cuz they will charge me a few hundred just to look at it. any one have some ideas? im tapped.
*just noticed my cruise control is not working either. hmmmmm
*note has APR 91 tune and Forge dv since spring 2010*
