Results 1 to 3 of 3
    Sep 28 2010
    ohio
    update ...well sorta..coil spring help
    i just got the car back from the shop and i was trying to locate the culprit of the howling sound in my rear end. it goes away when i swerve to the left so i thought possibly it was the right wheel bearing. io jacked the car up and tried to spin wheels independantly and hear , see any play either side there was none. i took the passenger side rear tire off and saw my coil spring was snapped and the inside of the tire is slightly worn. could the coil spring be making this noise. and also i wondered where to get a nice set of coil springs reasonable that will not lower the car . It is a 2001 audi s4. i currently have 18 inch tsw stettons with 235 45 18 bridgestones on it.
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    I'm sure the coil is the noise and stock springs are the only ones that will let you keep your 4x4 status
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Sep 28 2010
    ohio
    thanks gonna get that fixed as soon as i get one ordered
