Results 1 to 17 of 17
    Aug 28 2009
    ill
    What should I look for before I buy?
    The Engine blew on my 1996 A4, and I am looking to replace it with a B6 this week. My budget is Under $10K (not sure if I should even try at this price range). I found a few in the area, what issues should I check while looking?
    Veteran Member Four Rings IVRINGS's Avatar
    Mar 27 2009
    Columbus, Ohio
    Quote Originally Posted by mar10 View Post
    Main thing is that the TB is done by 70K. If it is not done just have it done before the deal or budget it into what you need to do.
    Deactivated Three Rings
    Nov 28 2009
    taxachusetts
    make sure the check engine light is on, abs and epc lights are on, there are multiple dents dings and scratches, has never had an oil change, leaks oil, has a blown coil pack so it misfires under high load/boost, bad tail lights, no radio, broken glovebox, vacuum leaks, front wheel drive, cvt, sketchy stains on the carpet, and the front grills are missing. then don't buy it.
    Aug 28 2009
    ill
    Thanks ivrings, Im paying for this car with cash that I have saved so I really dont want to be disappointed.
    Nov 28 2009
    taxachusetts
    make sure it's quattro!!!!!!
    Aug 28 2009
    ill
    I made the mistake of getting a FWD last time, thanks. I wanted a 5 speed this time are there any issues that i should note?
    Mar 27 2009
    Columbus, Ohio
    If you have some time try to find a 6-speed if you can. I really wished I could of looked more, but having two people and one car was killer. After being around the site I also really started to love the Avant's. I almost sold mine to get one, but didn't want to pay more at the time. Also if you plan on tryin' to do anything to the engine find a 1.8T. You might even find a car on here in that price range ever so often.
    Mar 27 2009
    Columbus, Ohio
    Also the 02 had some issues about chipping and different fuel maps that might make your life easier to get 03+, but there are some cheap 02s that look good. Here are a few on the site for sale.
    $6,800 Stock 02
    http://www.audizine.com/classifieds/...o-sedan&cat=65
    10,000 02 w/Big Turbo and Big Brakes
    http://www.audizine.com/classifieds/...-manual&cat=65
    13,500 a bit higher but newer and 6-speed 1.8
    http://www.audizine.com/classifieds/...o-fx400&cat=65
    But the best car I can find is this! USP 6-speed Quattro 1.8t 11,000 so worth 1,000 more then you have.
    http://www.audizine.com/classifieds/...-car-21&cat=65
    Aug 28 2009
    ill
    I found one that is local but he installed a aftermarket turbo ( claims to have a warranty) what do you think?
    http://chicago.craigslist.org/wcl/cto/1981671371.html
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    It honestly looks to be in very good shape appearance wise. It has a boost gage already, and aftermarket exhaust or at least mufflers or tips. I would ask about all the mods. It just says new turbo, not upgraded. I would bet it has been chipped due to the podi gage. Timing belt job done so that is a plus too.
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    This one is nice as well, but not local and USP.
    Nov 28 2009
    taxachusetts
    this looks good just make sure it's a genuine bw k03 and not some chinese ebay turbo and you should be good. has a podi so probably previously an enthusiasts car
    Nov 28 2009
    taxachusetts
    ps dolphin gray isn't rare ;-)
    Senior Member Two Rings Soolman32's Avatar
    Sep 10 2010
    03 A4 1.8t and 08 G37s coupe
    Minnesota
    I just recently got my 03 B6 1.8t with 69,5k on it for a lil over 10k. You can definitely get what you want in that price range. Things I paid attention to:
    -Make sure all the switches and lights work
    -Timing Belt
    -get quattro
    -check alignment on test drive
    -scratches and dents round the interior an exterior of car. the shifter bezel is likely to have some but easy to fix
    -Any weird smell and stains
    -any squeaks or rattle
    Mine must have been previously owned by a smoker coz it had a phunk to it. Nothing a full interior detail can't cure. If these check out ok then you'll most likely be fine.
    Aug 28 2009
    ill
    Cool thanks everyone.
    Senior Member Three Rings 102487thedude's Avatar
    Apr 06 2007
    BMW M3, X5 50, A4 BT
    Cresskill new jersey
    Do a compression test most important. the Compression tester is a 15 dollar iteam and well worth it. and you can do it in a parcking lot with the car owner.
    2.0 stroker, built aeb head, T3/TO4E t-61 BB F162 .63AR turbonetics turbo, front mount, open down pipe. Port and polished intake manifold. 800cc injectors.
    and a our New cayane GTS in red.
    visit,
    http://quicktimeperformance.com/
    http://www.theshopct.com/
    Aug 28 2009
    ill
    thanks thedude I would have never thought to do that
