Results 1 to 27 of 27
    Established Member Two Rings nfs1000f's Avatar
    Sep 22 2010
    1987 Honda Hurricane 1000. Gone: 1986 4000, 2001 A6, 2005 B7 S4
    VESTAL, NY
    5 hrs of hell and I have removed all the fasteners from the starter motor. Car would
    did not start yesterday so I thought I would DIY. Problem now is I cannot get the starter maneuvered out of the confines where it is mounted. I thought I read other members who were able to remove the starter w/out messing with engine mount. Will give it a go tomorrow.
    Dealer wanted 700+ for refurb and 1000+ for new motor. Oddly there were no symptoms leading up to when it stopped. After all this I hope it is in fact the starter.
    One of the fasteners easiest for me to get off, which proved very difficult for others from the searches I did, was the plastic connector at the very top. I found the tab, pushed on it and it came right off. Where I spent alot of time was trying to get the cable off the terminal on top next to the plastic connector. It wasn't until after I removed the plastic connector did I see I could now remove the wire. The 2 mounting bolts also took awhile because they were torqued on good. I used my legs by placing a foot on the wrench and pushing for all it was worth.
    Veteran Member Four Rings jfunkey's Avatar
    Jan 21 2009
    R32 B7/S4....2000 2.7t gone :(
    putting you into the wall
    ya bro sorry to see all that hastle.. For me.. I found you really need to jack up that one side off the sub frame to get a better angle to remove it..
    JHM war machine. Total transformation. JHM/Tune/headers/intake manifold.
    My B7S4. Faster then my old RS4 and First B7 S4 in the 12's
    AMA member
    USMC member (active)
    Facts first member. Built and supported by many
    Deactivated Three Rings
    Nov 15 2008
    04 Audi S4
    St. Paul, MN
    Is there a diy for the removal and installation of the starter? I have to do mine next week.
    Sep 22 2010
    VESTAL, NY
    Quote Originally Posted by rlee6462 View Post
    Here is what I used.
    http://www.audizine.com/forum/showth...ht=starter+diy
    Sep 22 2010
    VESTAL, NY
    Quote Originally Posted by jfunkey View Post
    What is involved to do it that way? I assume the side to jack up is the passenger side.
    Senior Member Two Rings dannslc's Avatar
    Dec 05 2006
    Dubai
    Where did you guys find a good deal on your new starters? Rlee did you get one here in the cities? I to have to do mine asap. Those start delays are getting longer and longer everyday. damn it.
    Veteran Member Four Rings SuperAvant's Avatar
    May 30 2007
    MA
    If you unscrew the solenoid from the motor those gives more than enough room to wiggle the assembly around to fit.
    Nov 15 2008
    04 Audi S4
    St. Paul, MN
    Quote Originally Posted by dannslc View Post
    I know what you mean, so I ordered mine asap! I got mine from JHM. My buddy is a mechanic, and looked up the part and his cost was like $560. JHM was half that. I think there are cheaper ones out there, but I trust JHM's quality, so I went with them.
    http://jhmotorsports.com/shop/catalo...216df0a52f9946
    Feb 01 2008
    04 Audi A4 cab
    Chicago
    Quote Originally Posted by nfs1000f View Post
    I had to remove the mount to get the starter out even with the motor out the car...
    Sep 22 2010
    VESTAL, NY
    What is involved in removing the mount?
    Dec 05 2006
    Dubai
    JHM's price is quite good but is it agod idea to buy another OEM starter anyway? I know we have limited options here but look at how the OEM has let us ALL down!
    Sep 22 2010
    VESTAL, NY
    Finally got starter out this morning. Had to remove solenoid. Even though it can be considered job only half done, I think the install will go better. I hope I don't f**k up the new starter installing it. Most of the searches I did prior to doing this job came up with people with with B6's who did it themselves and didn't seem to have the difficulty I did. Is the B7 different?
    Nov 15 2008
    04 Audi S4
    St. Paul, MN
    It may be oem, but I think it is a better starter. I don't believe our cars come stock with a valeo starter.
    Dec 05 2006
    Dubai
    yep, woke up today to head over to cars and coffee and sure enough NO START. Tried for 25 mins, usually it would have cranked on the 4-5 try. I think it got down to around 38 last night. She's done, new starter ordered!
    Nov 15 2008
    04 Audi S4
    St. Paul, MN
    Where did you order it from?
    Sep 08 2010
    B6S4
    santa ana
    So was it the starter that is the culprit? If it is, glad you got it going.
    Dec 05 2006
    Dubai
    I ordered it from JHM. It is definetly a better price. I did manage to get the car going today though. It needed to sit out in the warm sun for a few hours. Its like a crocodile. haha. what an ahole.
    Nov 15 2008
    04 Audi S4
    St. Paul, MN
    lol!
    Dec 05 2006
    Dubai
    So man whats the status? You get it all together yet? Hope its all good. I'm taking this job on at the end of this week. I'm scared haha
    Nov 15 2008
    04 Audi S4
    St. Paul, MN
    My buddy is doing mine this coming up weekend, and through his mechanics "how to" guide, it has a lot work and calls for 5 hours. I'm hoping that it isn't that big of a job.
    Sep 22 2010
    VESTAL, NY
    I am only ordering starter today. Did lots of research and found JHM the best source. I had thought about Parts Geek, but saw after a Google search that the customer service was suspect. I called 3 times to ask a question and to order and never spoke to anyone. I can only imagine what would happen if I had an issue or tried to get my core charge refunded. I have found no issues mentioned on this forum however. The starter from Parts Geek is half the price, but I have learned all to often the least expensive route is not always the best. Assuming I get the starter late this week, early next week I will post the results when I am done. I admit I am dreading the install based on how long it took to get it out. Once I removed the solenoid the starter came right out. Installing the solonoid after the starter has been re- installed will be very difficult considering the confines of the engine area I have to work in. May give in and pay someone to do it. That is assuming I can drive the car w/out the starter.
    Nov 15 2008
    04 Audi S4
    St. Paul, MN
    I'm paying my buddy the mechanic to do it, but it calls for special tools and to mount the engine up with special brackets which he doesn't have, so we are going to have to do the diy way.
    Sep 22 2010
    VESTAL, NY
    Good luck. Let us know how it goes. I hope you don't have the difficulty getting it out as I did.
    Anyone thats needs a starter i have a used one that is good. Cheap compared to new.
    Anyway, here are some pictures for reference. Gives you a better idea of what you have to work with.
    Alternator and Starter
    Close-up of Starter
    Starter bolts go through trans (when trans is attached)
    Try what jfunkey recommended by unbolting the passenger side motor mount and jacking that side of the motor up for clearance.
    Active Member Two Rings sappermk2's Avatar
    Aug 18 2009
    middletown ct
    Same price and starter from dealer with "discount" for being a tech... but would rather give JHM my buisness than dealer.
    Nov 15 2008
    04 Audi S4
    St. Paul, MN
    Here are some pics of how I replaced my starter. It only took 2.5 hours to do, and seemed fairly easy...of course it was done by a trained mechanic...who is my friend.
    Motor mount and other piece removed to allow more space.
    Starter Removed. It is a Valeo starter.
    This is where we went in and of the starter removed.
    Look at the space to work with.
    This is how we kept the motor in place after removing the motor mount.
    New starter in.
    Sep 22 2010
    VESTAL, NY
    Got it all back together and it works. Total time was maybe 8 hrs. I chose not to remove engine mounts but rather remove solenoid. If I had to do it again I could get it done in maybe 4 hrs.
