Results 1 to 2 of 2
    Jun 01 2010
    OH
    p0432, po441, po332, po411, po422 caused by exhaust leak?
    i had to cut the exhaust down right after the o2 sensors to work on the driveshaft. i was able to weld up the bottom when I put the exhaust back up, but on top it leaks some....car sounds loud. Deff. needs fixed. No check engine light was for days driving it like that but today on the highway i got the check engine light come on. codes are as follows:
    Could a exhaust leak cause this? I'm assuming the cats aren't getting hot enouph since there is leak right after them on both sides right by the o2 sensors......as for the knock sensor, maybe due to the noice of the exhaust leak?
    Thoughts suggestions?
    Thanks,
    This is on a 99 2.8 automatic.
    Veteran Member Four Rings Euromike's Avatar
    Oct 03 2008
    what garage?
    Pittsburgh
    P0411 is SAI incorrect flow.
    Doubt its related.
    01' B5 S4 Pearl White Stage 3+
    01' B5 S4 Laser Red [For Sale - ish.]
    16' Silverado HD
    12' Tornado Red GTI DSG
    99' Laser Red B5 A4 QM SOLD
    98' Santorin Blue B5 A4 QM SOLD
