Results 1 to 4 of 4
Thread: dumb question
    Veteran Member Three Rings omgwtfbbq!'s Avatar
    Jul 08 2009
    Daytona Beach, Fl
    dumb question
    ECS sells 3 oil sensors, the one that mounts on the bottom of the oil pan, a pressure sensor, and a temperature sensor. I have the priority 2 warning light that says my oil sensor is dead, and the temp gauge doesn't work. Do I need the $85 bottom of the pan sensor or the $12 temp sensor?
    Try not to flame me too hard.
    Other dumb questions:
    For HID fogs do we use the D2S bulbs or does it matter?
    I have a rattling sound coming from the front of the engine only when the AC/heat is on, thats the accessory belt tensioner correct?
    01 Sedan /// Brilliant Black ///F4H Frankenturbos w/ tubular manifolds /// J-Fonz stage 3- /// Borla 3" /// Darintake
    I hate: FMICs, flat colors, A-pillar gauge pods, vented hoods, drilled brake rotors, SSAC products, Rotas, you
    Jul 08 2009
    Daytona Beach, Fl
    So this thread: http://www.audizine.com/forum/showth...ts-%28B5-S4%29
    says H7 bulbs are the way to go.
    Veteran Member Four Rings bigern45's Avatar
    Sep 28 2009
    B5S4 stage 3, B9S5 Sportback
    ky
    12 dollar sensor is a no go. its the bottom of the oil pan sensor.
    RS6 hybrids and corn
    Jul 08 2009
    Daytona Beach, Fl
    that makes me a sad panda.
    Anyone have N75 valves in stock currently?
