Results 1 to 10 of 10
    Established Member Two Rings baungS4's Avatar
    Jul 05 2007
    Queens,NY
    anyone with SonicTuning HID Kits
    Anyone here running sonic tuning HID kits?
    I have a b6 s4 and when I tried to install the 3000k HID kit from sonictuning along with their cancellers, it didnt work. The fogs came on for a few seconds and then shuts off. I have returned the kit to them for testing as I cannot do anything to get it to work.
    Does anyone have it successfully installed in B6 S4?
    Thanks
    Registered User Four Rings sonictuning's Avatar
    May 13 2010
    Gaithersburg Maryland
    Just making sure everything is fixed!
    Sep 13 2008
    Western Chicago Burbs
    Almost everyone on here runs DDM tuning kits
    Veteran Member Four Rings mbgt72's Avatar
    May 18 2008
    2003 Jeep Wrangler
    Nashville TN
    ^^x2
    But to help, on the DDM kits, you need to reverse the polarity on the fogs. So that means you need to cut the wire and reverse them. I'd also take the error eliminators out b/c that's just an added step in diagnosing them. Get them running, and if you are getting bulb out errors, then plug them in and see if they're working.
    Basically I'd say:
    1)remove error eliminators and try
    2)If they're still not working, then you'll probably need to try reversing the polarity (which may mean you can't return, so your risk). If you don't want to do that, then you can return and get the DDM and people will be able to provide much better support.
    3)If they're working with the reversed polarity but they throw an error (some do, some don't, haven't really seen a consensus on which models do and don't, my 2005.5 didn't need them), try the error cancelers. They should still work, but if not you may need to play with the polarity at that point again.
    I would highly suggest just getting them working without the code eliminators though so that you can at least know what works and what doesn't. Also, I'm sure you're well aware, but make sure you don't ever touch the bulb part with your hands/fingers. The slight grease can cause premature failure and even to explode (timeframe can be almost instant to running for while but then going out).
    Current: 996TT
    Sold but not forgotten: 2005.5 S4 MT6 l JHM Parts: Stg 1 S/C, LTH, IM, SS Trio, LW Front Rotors, LWFW, Stg IV clutch, 4:1 Diff, Stern Motor Mounts, Snub/Trans/Diff Mounts, F.I.Exhaust l H&R C.O. 24.75" G-F, 034 Adj UCA's, H-Sport RS4 Rear Sway l Hawk HPS Pads, SS lines & SuperBlue l Fly'sV4 LEDs l 15% Tint, 50% Front l VMR V710 GM 19" & Enkie RPF01's l JL 10W7, Focal Components l V1 Mirror Display l
    May 13 2010
    Just looked through my inbox, everything is fixed.
    No need to reverse polarity with our kits, plug and plug and no error codes.
    Thanks for the help everyone
    Veteran Member Three Rings road race s4's Avatar
    Jan 03 2009
    camry
    Quote Originally Posted by mbgt72 View Post
    ^^x2
    I have the DDM HID fogs and I didn't have to reverse polarity or to cut/modify anything.
    Veteran Member Three Rings noznab's Avatar
    Jul 08 2007
    Tri-State
    Quote Originally Posted by road race s4 View Post
    X2
    I've had mine for over 2 years now with no problems... Well one ballast did burn out within 24hrs of initial installation. After a going back and forth with DDM for a while they sent me a new set + paid for shipping both ways
    A few mods here and there
    May 18 2008
    2003 Jeep Wrangler
    Nashville TN
    ^^ search around some, you'll see it's a common issue. Originally they were fine and it wasn't an issue, then the supplier for DDM apparently changed something, and DDM even admits that it's a problem that is really only solved by reversing the polarity. That's why I brought it up. DDM was trying to change parts supplier, or get their supplier to change, so the issue wouldn't continue.
    I wasn't saying that this was definitely the case with his, just that there was a decent chance they could be having the same issues as the DDM ones. Depending how long ago you bought your DDM lights, they could have been fine, after that date, most have had to reverse the polarity.
    Current: 996TT
    Sep 13 2008
    ^^ I just got a new set of DDM fogs about a month ago an they worked out of the box. I guess they resolved the issue. maybe its a B7 problem
    Jul 08 2007
    Tri-State
    IIRC, it was mostly only B7's that had the fog out warning problem. Some of the later B6's did too, but from what I've gathered 04's didn't need the code eliminators
