Results 1 to 3 of 3
    Registered User Four Rings Doug@FrankenTurbo's Avatar
    Oct 19 2009
    Gary Fisher Sugar 2+, Trek HiFi 29er
    Portlandish
    3" VR6 (Big MAF) mod ** workable?
    For those of you B5 guys running without a MAP sensor in your cars (AEB/AJL engine codes), has anyone successfully tried a "Big MAF mod"? The idea goes like this: place your OEM sensor in a large, 3" MAF housing. The car will now be ingesting a quantity of un-metered air, which requires compensation in the fueling. The solution to that is a size increase directly in proportion to the airflow increase. In the case of an AEB with 210cc injectors (with a 4bar FPR) would be 317cc injectors (still at 4bar).
    I know this mod (okay, it's really more of a hack) has gotten done. In fact here is a forum thread which more or less covers it. But does anyone else have experience with it?
    Veteran Member Four Rings lowandslow4now's Avatar
    Jul 12 2008
    Cumming, GA
    When I first went BT I experimented with 630's and a 4" maf on a UNI 440 file. It ran OK I was going to fine tune it with a split second psc-1. I ended up switch back to the recommended injectors and maf housing for the file. I wasn't planning on building the internals so I didn't need all the fueling.
    Now 2001 B5 S4
    Former B5 A4, 034 Stage 3 BT, Unitronics,H&R,etc,etc
    Jan 23 2009
    eastcoast
    I have a custom aluminum "vr6" maf housing for sale if you interested. PM me
    99 2L BAT A4
